OTV Unicast-only mode
lm20ele
I am configuring OTV Unicast mode and when configuring the Overlay interface, specificaly the "otv joing-interface e1/5", I receive the following message:
OTV needs join interfaces to be configured for IGMP version 3.
Do I need to configure this?
Rick1776
Level 5
Level 5
under the OTV interface make sure you use
otv adjacency-server unicast-only
otv use-adjacency-server 10.10.2.2 unicast-only
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/wan_otv/configuration/xe-3s/wan-otv-xe-3s-book/wan-otv-adj-server.html
For the join int just use the command igmp version 3 this won’t effect anything as you have the Unicast server configuration already.
Vivek Ganapathi
Level 4
Level 4
Hi Luis,
You don't need IGMP to be enabled for OTV unicast only mode. Probably you hit an order of operation issue. Did you configure the OTV adjacency-server unicast-only command underneath the OTV overlay interface before linking the join-interface to the overlay? Please try & advise.
Vivek
