OTV Unicast with dual AEDs
Gavin Lodge
I have deployed OTV in a lab environment and are experiencing a strange problem. The topology is two DCs each comprising of 2 x OTV VDCs and 2 x Core VDCs.
I'm having an issue where only traffic for one vlan(164) will pass across the overlay, the overlay interfaces are up and layer 2 adjacencies are working for vlan164.
Running the ‘show otv isis adjacencies’ I can see that each otv VDC has communication to all the OTV edge devices on the overlay.
Here are some show command outputs from OTV edge VDC 1 at dc1, there results are the same for all DCs.
Dc1-nx7010-otv-01# sho otv isis adjacency
OTV-IS-IS process: default VPN: Overlay0
OTV-IS-IS adjacency database:
System ID       SNPA           Level State Hold Time Interface Site-ID
e4c7.2201.a844 e4c7.2201.a844 1     UP     00:00:51   Overlay0 0000.0000.0002
e4c7.2201.b244 e4c7.2201.b244 1     UP     00:00:46   Overlay0 0000.0000.0002
e4c7.2203.9244 e4c7.2203.9244 1     UP     00:00:57   Overlay0 0000.0000.0001
dc1-nx7010-otv-01# sho otv
OTV Overlay Information
Site Identifier 0000.0000.0001
Overlay interface Overlay0
VPN name           : Overlay0
VPN state           : UP
Extended vlans     : 163-164 (Total:2)
Join interface(s)   : Eth1/3 (10.100.1.22)
Site vlan           : 850 (up)
AED-Capable         : Yes
Capability         : Unicast-Only
Is Adjacency Server : Yes
Adjacency Server(s) : 10.100.1.22 / [None]
dc1-nx7010-otv-01# sho otv site
Dual Adjacency State Description
   Full     - Both site and overlay adjacency up
   Partial - Either site/overlay adjacency down
   Down     - Both adjacencies are down (Neighbor is down/unreachable)
        - Site-ID mismatch detected
Local Edge Device Information:
   Hostname lon1-nx7010-otv-01
   System-ID e4c7.2203.1ec4
   Site-Identifier 0000.0000.0001
   Site-VLAN 850 State is Up
Site Information for Overlay0:
Local device is AED-Capable
Neighbor Edge Devices in Site: 1
Hostname                 System-ID       Adjacency-       Adjacency-   AED-
                                         State           Uptime       Capable
dc1-nx7010-otv-02       e4c7.2203.9244   Full             1d02h       Yes
DC 1
dc1-nx7010-otv-01
vlan 163-4,850
otv site-vlan 850
interface Overlay0
otv join-interface Ethernet1/3
otv extend-vlan 163-164
otv use-adjacency-server 10.100.1.22 unicast-only
otv adjacency-server unicast-only
no shutdown
otv site-identifier 0x1
no switchport
mtu 1600
ip address 10.100.1.22/30
no ip ospf passive-interface
ip router ospf 10 area 0.0.0.35
no shutdown
dc1-nx7010-otv-02
vlan 163-4,850
otv site-vlan 850
interface Overlay0
no shutdown
no switchport
mtu 1600
ip address 10.100.1.18/30
no shutdown
DC 2
dc2-nx7004-otv-01
vlan 163-4,800
otv site-vlan 800
interface Overlay0
otv join-interface Ethernet4/3
no shutdown
otv site-identifier 0x2
mtu 1600
ip address 10.100.1.5/30
no shutdown
dc2--nx7004-otv-02
vlan 163-4,800
otv site-vlan 800
interface Overlay0
no shutdown
mtu 1600
ip address 10.100.1.2/30
no shutdown
I would appreciate some help with this as I'm going round in circles trying to figure out what is wrong as the config looks fine and is working for one vlan.
Steve Fuller
Level 9
Level 9
Hi Gavin,
One thing that looks odd in the configuration you've supplied is the vlan 163-4,850 and vlan 163-4,800 commands. I think this would create VLANs in the range 4 to 163 and 850 in DC1, and 4 to 163 and 800 in DC2, and not VLANs 163, 164, 800 and 850 as you want.
In all Nexus I've looked at the VLAN configuration would appear as something along the lines of vlan 163-164, 850 i.e., 164 should be in full and not only a numeric 4. Can you confirm whether this is the case or if it's simply that the syntax is different.
You should see be able to see the VLANs that are active with the show vlan and show otv vlan commands.
Hi Steve
Thanks for the quick reply, that was a typo(the only  section that I didn't copy and paste). Below is the 'show otv vlan'  output. Interesting the I can't see any otv routes for vlan 163 for DC 1  when running 'show otv route' on dc2-nx7004-otv-01:
dc1-nx7004-otv-01# sho otv route
OTV Unicast MAC Routing Table For Overlay0
VLAN MAC-Address     Metric  Uptime    Owner      Next-hop(s)
163 0000.0c07.aca3  1       03:21:47  site       port-channel401
163 e4c7.2201.a842  1       03:21:47  site       port-channel401
163 e4c7.2201.a844  1       03:21:40  site       port-channel401
164 0000.0c07.aca4  42      03:24:36  overlay    dc1-nx7010-otv-01
164 7081.0564.e23f  42      03:24:36  overlay    dc1-nx7010-otv-01
164 e4c7.2203.1ec2  42      03:24:36  overlay    dc1-nx7010-otv-01
164 e4c7.2203.9242  42      03:24:36  overlay    dc1-nx7010-otv-01
164 e4c7.2203.9244  42      03:24:36  overlay    dc1-nx7010-otv-01
dc1-nx7010-otv-01#sho otv vlan
OTV Extended VLANs and Edge Device State Information (* - AED)
Legend:
(NA) - Non AED, (VD) - Vlan Disabled, (OD) - Overlay Down
(DH) - Delete Holddown, (HW) - HW: State Down
(NFC) - Not Forward Capable
VLAN   Auth. Edge Device                     Vlan State                 Overlay
163   dc1-nx7010-otv-02                    inactive(NA)            Overlay0
164*  dc1-nx7010-otv-01                    active                  Overlay0
dc1-nx7010-otv-02#sho otv vlan
Legend:
163*  dc1-nx7010-otv-02                    active                  Overlay0
164   dc1-nx7010-otv-01                    inactive(NA)            Overlay0
dc2-nx7004-otv-01# sho otv vlan
Legend:
163*  dc2-nx7004-otv-01                    active                  Overlay0
164   dc2-nx7004-otv-02                    inactive(NA)            Overlay0
dc2-nx7004-otv-02# sho otv vlan
Legend:
163   dc2-nx7004-otv-01                    inactive(NA)            Overlay0
164*  dc2-nx7004-otv-02                    active                  Overlay0
Hi Gavin,
Can you confirm where the show otv route you pasted was taken? In the text you state dc2-nx7004-otv-01, but the prompt on the capture shows dc1-nx7004-otv-01.
Presumably when you run show otv route on dc1-nx7010-otv-01 and dc2-nx7004-otv-02 i.e., the AED for VLAN164, in both ED you're seeing MACs for VLAN 164 with some MACs having the owner as the site and others the overlay?
What do we see with a show otv route in dc1-nx7010-otv-02? Hopefully we're actually seeing MACs learnt on the internal interface i.e., the AED for VLAN 163 has the VLAN allowed on its internal interface and we're actually learning MACs in VLAN 163?
