Frequent Contributor
PoAP message on Nexus switch
We are seeing this message continually coming from our new Nexus switch. Is this a problem?
how do we subdue this.
2013 Aug 13 04:05:34 switch %$ VDC-1 %$ %POAP-2-POAP_DHCP_DISCOVER_START: POAP DHCP Discover phase started
2013 Aug 13 04:05:34 switch %$ VDC-1 %$ %POAP-2-POAP_INFO: Abort Power On Auto Provisioning and continue with normal setup ?(yes/no)[n]:
2013 Aug 13 04:05:34 switch %$ VDC-1 %$ %POAP-2-POAP_FAILURE: POAP DHCP discover phase failed
2013 Aug 13 04:05:39 switch %$ VDC-1 %$ %POAP-2-POAP_DHCP_DISCOVER_START: POAP DHCP Discover phase started
Thanks for all inputs.
1 ACCEPTED SOLUTION
Engager
The message is caused by the Cisco PowerOn Auto Provisioning process. This is a feature that simplifies upgrading software and installing configuration files on new Cisco Nexus switches. This is not a problem assuming the switch has just been installed and has not yet been configured.
To stop the messages you simply press Y and return at the prompt "%POAP-2-POAP_INFO: Abort Power On Auto Provisioning and continue with normal setup ?(yes/no)[n]:"
8 REPLIES 8
Engager
Re: PoAP message on Nexus switch
My console is unresponsive after this message
"POAP DHCP discover phase failed"
Unable to type anything. Anyother option to proceed further?
Beginner
I have a same issue. the console is unresponsive
Beginner
Same here. How can I exit POAP?? I just cannot press "y"
Beginner
Fixed for me with taking another usb-to-com.
Beginner
this is not fixing for me still same issue occuring after pressing Y, even its not taking Y , seems console is unresponsive and continue same error message coming as below.
2019 Jul 11 13:44:11 switch %$ VDC-1 %$ last message repeated 1 time
2019 Jul 11 13:44:11 switch %$ VDC-1 %$ %POAP-2-POAP_DHCP_DISCOVER_START: [FDO224507HJ-00:3A:9C:3B:2A:87] - POAP DHCP Discover phase started
2019 Jul 11 13:44:11 switch %$ VDC-1 %$ %POAP-2-POAP_FAILURE: [FDO224507HJ-00:3A:9C:3B:2A:87] - POAP DHCP discover phase failed
2019 Jul 11 13:44:16 switch %$ VDC-1 %$ %POAP-2-POAP_INFO: [FDO224507HJ-00:3A:9C:3B:2A:87] - USB Initializing Success
2019 Jul 11 13:44:16 switch %$ VDC-1 %$ %POAP-2-POAP_INFO: [FDO224507HJ-00:3A:9C:3B:2A:87] - USB disk not detected
2019 Jul 11 13:44:16 switch %$ VDC-1 %$ last message repeated 1 time
Highlighted
Beginner
i wa salso facing same issue after unplug console and again connect  console and take fresh putty then its working fine .
try its i work after reopen putty n console.
Content for Community-Ad
July's Community Spotlight Awards
