Prime Device Pack 1 is already part of PI 3.10 error
Hi all,
we did an upgrade to PI 3.10.2 System Patch 1.0.5 + PI 3.10.2 with Prime Data Migration Tool Update 04 1.0.0 + PI 3.10.3 Release 1.0.0, then got message: Prime Infrastructure 3.10 Device Pack 1 Restart Required Version 1.0 PI 3.10
and following error at "Install" - Prime Infrastructure 3.10 Device Pack 1 is already part of PI 3.10.2.
are only the APs1830, 2600, 2700 and 2800 shown, but C9120AXI-E are missing, probably because of the same issue;
PI1:loading DP1 - therefore upgrade needs to finish and then comes the above error:
may you advise what we did wrong ?
Best Regards
balaji.bandi
if you already have patch 2 - then you need to install
BB
