Prime infrastructure 2.1 configuration archive rollback fails on WLC
Jack Shields
Does cisco prime infrastructure 2.1 support  roll back of a WLC running configuration to a previous version ?
rosaho
Level 3
Level 3
This discussion has been reposted from Additional Communities to the Cisco Prime Network Services Controller community.
gtognin
Hi Jack,
did you find what you were looking for? I've got same issue with 2.2 version too.
Thank you,
G.
Hi G
Yes we found that we could actually rollback configurations
on further testing it appears that Prime reports rollback as a partial fail because it does not overwrite the complete configuration - it only changes the differences in config between the two versions.
I figure that, because the configuration has been  returned to the previous state, I can ignore the error message
Good news! We're animating discussing with Cisco TAC about this issue. They affirm that configuration rollback is not possible.
Have you tried to delete a WLAN configuration and tried to rollback with Prime?
Thank you.
