Problem reset Nexus 5596
Some equipments Nexus 5596 from a customer have reinitiated and it seems to have been provoked by an OSPF problem although I am not sure.
The logs from the equipment show:
2013 Jan  9 07:29:42 ROISBPRE2CN %BTCM-5-BTCM_LOG_L3_READY: system becomes L3 Ready
2013 Jan  9 07:29:44 ROISBPRE2CN %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by  on ppm.3726
2013 Jan  9 07:29:45 ROISBPRE2CN %OSPF-5-ADJCHANGE:  ospf-1 [3236]  Nbr 180.101.250.26 on Vlan902 went TWOWAY
2013 Jan  9 07:29:48 ROISBPRE2CN %OSPF-5-ADJCHANGE:  ospf-1 [3236]  Nbr 180.101.250.29 on Vlan902 went TWOWAY
2013 Jan  9 07:29:49 ROISBPRE2CN %OSPF-5-ADJCHANGE:  ospf-1 [3236]  Nbr 180.101.250.28 on Vlan902 went TWOWAY
2013 Jan  9 07:29:52 ROISBPRE2CN %OSPF-5-ADJCHANGE:  ospf-1 [3236]  Nbr 180.101.250.17 on Vlan902 went TWOWAY
2013 Jan  9 07:29:52 ROISBPRE2CN %OSPF-5-ADJCHANGE:  ospf-1 [3236]  Nbr 180.101.250.29 on Vlan902 went FULL
2013 Jan  9 07:29:52 ROISBPRE2CN %OSPF-5-ADJCHANGE:  ospf-1 [3236]  Nbr 180.101.250.26 on Vlan902 went FULL
2013 Jan  9 07:30:41 ROISBPRE2CN %ETHPORT-5-IF_DOWN_INITIALIZING: Interface port-channel902 is down (Initializing)
2013 Jan  9 07:30:41 ROISBPRE2CN %ETHPORT-5-IF_DOWN_INITIALIZING: Interface port-channel100 is down (Initializing)
2013 Jan  9 07:30:41 ROISBPRE2CN %ETHPORT-5-IF_DOWN_INITIALIZING: Interface Ethernet1/31 is down (Initializing)
2013 Jan  9 07:30:41 ROISBPRE2CN %ETHPORT-5-IF_DOWN_INITIALIZING: Interface Ethernet1/32 is down (Initializing)
2013 Jan  9 07:30:41 ROISBPRE2CN %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBERS_DOWN: Interface port-channel112 is down (No operational mem
bers)
2013 Jan  9 07:30:41 ROISBPRE2CN %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBERS_DOWN: Interface port-channel111 is down (No operational mem
bers)
I wanted to know if you know something about a problem with OSPF in next version:
  cisco Nexus5596 Chassis ("O2 48X10GE/Modular Supervisor")
  Intel(R) Xeon(R) CPU         with 8263880 kB of memory.
   bootflash:    2007040 kB
Kernel uptime is 0 day(s), 2 hour(s), 25 minute(s), 35 second(s)
System version: 5.1(3)N1(1a)
Thank you very much.
Andras Dosztal
Level 3
Level 3
  • OSPF logs say that your switch is fully adjacent with 180.101.250.26 and .29, this means normal operation.
  • Bi-directional communication has been established between the Nexus and 180.101.250.17 and .28. They are in the middle of the OSPF neighboring process.
  • Some interfaces are initializing, and Po111 and 112 have no member ports (the channel-group <111|112> command hasn't been issued on any physical interfaces).
More information about OSPF neighbor states can be found here.
Andras Dosztal
Level 3
Level 3
Thank you very much a_dosztal. As you have said, this is normal behaviour and anything about this log should have provoked the reset of the equipment. I have looked the status of the modules and I have seen a power supply is failed, maybe this has been the origin of the problem although this shouldn't be a problem. There are redundant power supplies.
Well, thank you very much!!!! Best regards. And thank you for being so quick answering me.
