ā07-12-2012 03:14 AM - edited ā03-01-2019 07:08 AM
I have maybe a bug on my Nexus 5596 switch ; when i issue the command show interface status the outpout of the "port" is missing :
# sh int statu
Port Name Status Vlan Duplex Speed Type
connected trunk full 10G 1/10g
disabled trunk full 10G 1/10g
sfpAbsent 1 full 10G 1/10g
Eth1/7 ### ***********- connected trunk full 10G 1/10g
Eth1/8 ### *************- connected trunk full 10G 1/10g
disabled 1 full 10G 1/10g
connected 1 full 10G 1/10g
SDP timed 1 full 10G 1/10g
But we see the fex interfaces :Eth101/1/1, Eth103/1/1, etc...
Eth101/1/1 *** ****************connected full 1000 --
Eth101/1/2 *** *************** connected full 1000 --
Eth101/1/3 **
I have other 5596 with the same version 5.0(3)N2(2a) and there is no problem ; i do nothing for this, it was working before but now it's not.
Did you seen this problem before ?
Thanks for your feedback.
ā07-13-2012 06:42 AM
on this switch, do you remember copying any files created via windows/dos to the running config lately? can you paste a sample 'show interface ethernet x/y' for the port which is missing the port information in 'show int status'
Thanks, Vinayak
ā07-13-2012 07:03 AM
Yes when i implement a config, i always work with notepad or word and copy/paste the configuration on the Nexus.
Here is the outpout that you asked :
N5K# sh int eth1/19
Ethernet1/19 is down (SFP validation failed)
Hardware: 1000/10000 Ethernet, address: 547f.ee92.1e1a (bia 547f.ee92.1e1a)
Description:
MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
Encapsulation ARPA
Port mode is access
auto-duplex, 10 Gb/s, media type is 10G
Beacon is turned off
Input flow-control is off, output flow-control is off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
Last link flapped never
30 seconds input rate 0 bits/sec, 0 bytes/sec, 0 packets/sec
30 seconds output rate 0 bits/sec, 0 bytes/sec, 0 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
RX
0 unicast packets 0 multicast packets 0 broadcast packets
0 input packets 0 bytes
0 jumbo packets 0 storm suppression bytes
0 giants 0 input error 0 short frame 0 overrun 0 underrun
0 watchdog 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
0 output packets 0 bytes
0 jumbo packets
0 output errors 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble
0 Tx pause
0 interface resets
And an outpout for an interface that is working :
N5K# sh int eth1/7
Ethernet1/7 is up
Description:
Encapsulation ARPA
Port mode is trunk
full-duplex, 10 Gb/s, media type is 10G
EtherType is 0x8100
Last link flapped 1week(s) 0day(s)
30 seconds input rate 61184 bits/sec, 7648 bytes/sec, 41 packets/sec
30 seconds output rate 109040 bits/sec, 13630 bytes/sec, 55 packets/sec
input rate 55.00 Kbps, 32 pps; output rate 162.62 Kbps, 74 pps
RX
28917792 unicast packets 6436428 multicast packets 2340725 broadcast packets
37694945 input packets 9441476437 bytes
1471043 jumbo packets 0 storm suppression bytes
0 Rx pause
TX
427409737 unicast packets 91135 multicast packets 414674 broadcast packets
427915546 output packets 44591976368 bytes
1729034 jumbo packets
0 Tx pause
1 interface resets
Thanks for your help
ā07-13-2012 07:41 AM
Thanks. There could be an issue with line characters after copying over the config from your notepad in windows. You can refer to the following command
nexus# d?
debug Debugging functions
debug-filter Enable filtering for debugging functions
delete Delete a file or directory
diff-clean Remove temp files created by '| diff' filters
dir List files in a directory
dos2nxos DOS to NXOS text file format converter <<<<
nexus# dos2nxos ?
bootflash: Filename to be displayed
debug: Filename to be displayed
modflash: Filename to be displayed
usb1: Filename to be displayed
volatile: Filename to be displayed
since you copy the configs frequently, you can use the dos2nxos command to convert the file to nxos first and then use the file for configuration. Right now, try to modify the config manually on the switch interfaces and see if that helps. You either readd 'description' command under the interface and check if the port starts showing up in 'show int status' or modify or repaste the entire interface config and check if that works.
Thanks, Vinayak
ā07-16-2012 08:22 AM
Thanks for the support ! after readding the description on the interfaces, the sh int status is now ok !
Thanks again !
