10-04-2018 12:26 PM - edited 03-01-2019 08:50 AM
Hello everyone.
I am trying to update my nexus from version n3500-uk9.6.0.2.A8.7b.bin to version nxos.7.0.3.I7.2.bin, it shows me the following error.
Verifying image bootflash:///nxos.7.0.3.I7.2.bin for boot variable "nxos".
[# ] 2% -- FAIL. Return code 0x40930084 (Upgrade cannot be continued with non-compact image!. Please use scp compacting for a compact image and retry ISSU.).
But it necessarily indicates to me that it is necessary to use the scp, I am trying to configure it but for some reason my nexus do not accept aaa new-model and the ip scp server enable command does not work either.
Is there any other way to perform this update?
I would also like to know if there is any other way to make compact images.
10-04-2018 12:55 PM - edited 10-04-2018 12:58 PM
Suggest to read same kind of issue.
Also suggest to verify the upgrade path for your requirement to nxos.7.0.3.I7.2
Make sure you have all the backup and do upgrade under maintenance window always suggested.
11-05-2018 06:45 PM
This chapter describes how to upgrade or downgrade the Cisco NX-OS software. It contains the following sections:
refer the link below:-
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/sw/upgrade/7_x/b_Cisco_Nexus_3500_Series_NX-OS_Software_Upgrade_and_Downgrade_Guide_Release_7x/b_Cisco_Nexus_3500_Series_NX-OS_Software_Upgrade_and_Downgrade_Guide_Release_7x_chapter...
