Production Site to DR site Network Design
piusnolih
I have a Prod network with the following Switches as Core: Cisco9336C-FX2 36Port 40/100G port density.
Our Link is only 100Mbps and can go up to 1G and we intend to install a Similar Model Switch at DR for Active/Active Replication.
We intend to achieve Active-Passive in phase 1 and Active/Active in phase2.
Are we able to carryout a VPC or using 2 MPLS from providers using qinq or vxlan?
Also the Core switches only have 40G/100G and provide can only go up to 1G, will that be possible as well?
Just need guindance on the design and configuration steps?
balaji.bandi
Its all depends on what already configured and what configuration major you can change.
You can use different methods - if you looking to extended the VLAN suggest to use VXLAN (check the guide lines and documentation for the requirement).
Other Option you can also use OTV.
check some deployment methods :
https://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Data_Center/DCI/4-0/EMC/dciEmc/EMC_2.html
BB
