protocol resides??
danielbarnabas
hi there,
               i wanna know wher protocols of all layers in OSI model reside. either these are firmware or embedded ? if anyof it wher would it b found in machine?? hope im clear...
Hi Daniel,
As you know the OSI is a layered approach where it defines protocol for specific function in each layer.
To achieve this functionality all there referenced protocols will be integrated in the IOS software (Basically an operating system) if you take an example of Cisco Routers.
An exception to this is the physical layer - in which the physical layer defines the cabling and adapter specification etc.
http://en.wikipedia.org/wiki/OSI_model
Hope this help
regards
Muhammed M
@ muhammed :  hmmm lik wil those protocols b comin with our operating system? or it s a n embedded coding tat resides in any chip of our machine??
It will be reside in the IOS code itself ( Operating sytem
) not in the chip.
regards
Muhammed M
wow   tats cool, thanks....
