QoS issue with Nexus 5548UP
hugo.girard
I configured QoS on Nexus 5548UP but "show queuing" command don't return the correct result. In TX and RX, I only show two qos-group (qos-group 0 et qos-group 2). Normaly, I must have 5 qos-group.
Do you have any ideas ?
Hugo
I send you the configuration below :
sw-fo# show running-config ipqos
!Command: show running-config ipqos
!Time: Tue Jan 27 15:20:02 2009
version 5.1(3)N2(1a)
class-map type qos class-fcoe
class-map type qos match-any IN-VIDEO
  match dscp 34
  match cos 4
class-map type qos match-any IN-VOICE
  match dscp 46
  match cos 5
class-map type qos match-any IN-iSCSI
  match access-group name iSCSI-ACL
class-map type qos match-any COS1-GLOBAL
  match cos 1
class-map type qos match-any COS2-GLOBAL
  match cos 2
class-map type qos match-any COS3-GLOBAL
  match cos 3
class-map type qos match-any COS4-GLOBAL
  match cos 4
class-map type qos match-any COS5-GLOBAL
  match cos 5
class-map type qos match-any IN-SIG-VOICE
  match dscp 26
  match cos 3
class-map type queuing class-fcoe
  match qos-group 1
class-map type queuing QUEUING-VIDEO
  match qos-group 4
class-map type queuing QUEUING-VOICE
  match qos-group 5
class-map type queuing QUEUING-iSCSI
  match qos-group 2
class-map type queuing class-all-flood
  match qos-group 2
class-map type queuing QUEUING-SIG-VOICE
  match qos-group 3
class-map type queuing class-ip-multicast
  match qos-group 2
policy-map type qos CLASSIFY-GLOBAL
  class COS5-GLOBAL
    set qos-group 5
  class COS4-GLOBAL
    set qos-group 4
  class COS3-GLOBAL
    set qos-group 3
  class COS2-GLOBAL
    set qos-group 2
  class COS1-GLOBAL
    set qos-group 1
  class class-default
policy-map type qos IN-CLASSIFY-SERVER-N5K
  class IN-VOICE
    set qos-group 5
  class IN-VIDEO
    set qos-group 4
  class IN-SIG-VOICE
    set qos-group 3
  class IN-iSCSI
    set qos-group 2
  class class-default
policy-map type queuing QUEUING-GLOBAL
  class type queuing QUEUING-VOICE
    priority
    bandwidth percent 10
  class type queuing QUEUING-VIDEO
    bandwidth percent 20
  class type queuing QUEUING-SIG-VOICE
  class type queuing QUEUING-iSCSI
    bandwidth percent 40
  class type queuing class-default
class-map type network-qos iSCSI-NQ
  match qos-group 2
class-map type network-qos class-fcoe
  match qos-group 1
class-map type network-qos class-all-flood
  match qos-group 2
class-map type network-qos class-ip-multicast
  match qos-group 2
policy-map type network-qos GLOBAL-NQ
  class type network-qos iSCSI-NQ
    mtu 9216
  class type network-qos class-default
    multicast-optimize
system qos
  service-policy type qos input CLASSIFY-GLOBAL
  service-policy type queuing output QUEUING-GLOBAL
  service-policy type queuing input QUEUING-GLOBAL
  service-policy type network-qos GLOBAL-NQ
sw-fo# show running-config interface ethernet 1/30
!Command: show running-config interface Ethernet1/30
!Time: Tue Jan 27 15:20:55 2009
sw-fo# show queuing interface ethernet 1/30
Ethernet1/30 queuing information:
  TX Queuing
    qos-group  sched-type  oper-bandwidth
        0       WRR             20
        2       WRR             40
  RX Queuing
    qos-group 0
    q-size: 410560, HW MTU: 1500 (1500 configured)
    drop-type: drop, xon: 0, xoff: 410560
    Statistics:
        Pkts received over the port             : 0
        Ucast pkts sent to the cross-bar        : 0
        Mcast pkts sent to the cross-bar        : 0
        Ucast pkts received from the cross-bar  : 0
        Pkts sent to the port                   : 0
        Pkts discarded on ingress               : 0
        Per-priority-pause status               : Rx (Inactive), Tx (Inactive)
    qos-group 2
    q-size: 29760, HW MTU: 9216 (9216 configured)
    drop-type: drop, xon: 0, xoff: 29760
    Statistics:
  Total Multicast crossbar statistics:
    Mcast pkts received from the cross-bar      : 0
vdsudame
Hi Hugo
If you need all qos-groups defined under 'show queuing interface ethernet x/y' output then you will need to define that many class-maps for network-qos matching qos-group 1,3,4,5. And then call them under policy-map network-qos.
So this is what you currently have,
  match qos-group 2
    mtu 9216
     multicast-optimize
but you need separate class-maps which match other qos-groups.
class-map type network-qos A
match qos-group 1
class-map type network-qos B
match qos-group 3
class-map type network-qos C
match qos-group 4
class-map type network-qos D
match qos-group 5
and then call these under policy-map network-qos in addition to what you currently have:
class type network-qos A
class type network-qos B
class type network-qos C
class type network-qos D
This should populate the rest of the qos-groups.
Thanks, Vinayak
vdsudame
Hi Hugo
  match qos-group 2
    mtu 9216
     multicast-optimize
match qos-group 1
match qos-group 3
match qos-group 4
match qos-group 5
Thanks, Vinayak
Hi Vinayak,
That's right. This issue is fixed.
Thanks.
