03-27-2015 02:46 AM - edited 03-01-2019 07:51 AM
On the Cisco WS-3560V2-48TS-E (IOS Version 12.2(50)SE3) Switches we used “Conditional Trust” in our QoS marking based on the “trust dscp” IOS CLI command as shown in the next IOS CLI configuration segment.
ip access-list extended CLASSIFY_MARKED
deny ip any any dscp default
permit ip any any
ip access-list extended CLASSIFY_MANAGEMENT
permit ip ---
class-map match-all ALLREADY_MARKED
match access-group name CLASSIFY_MARKED
class-map match-all CLASS_MANAGEMENT
match access-group name CLASSIFY_MANAGEMENT
policy-map MARK_INGRESS
class ALLREADY_MARKED
trust dscp
class CLASS_MANAGEMENT
set dscp cs3
interface FastEthernet0/1
service-policy input MARK_INGRESS
The above IOS CLI command segment leaf all dscp marked incoming frames (dscp <> 0) untouched and all not dscp marked incoming frames (dscp = 0) are marked according a configured scheme (not fully show in the above IOS CLI command segment).
The form Cisco recommended successor the WS-C3560-48TS-E (IOS XE Version 03.03.04SE) doesn’t support the “trust dscp” IOS CLI command anymore.
Does anybody know a way to configure the same functionality in IOS XE.
04-14-2015 10:57 AM
I guess trust dscp is on by default.
Hope this helps.
Madhu
04-14-2015 11:04 PM
Thanks you for your response.
Yes you’re right there, but the problem is that if an incoming packed has a dscp value 0 (not marked) than it should be remarked and only then. Therefore I need the trust dscp command as shown in the IOS CLI configuration segment I posted, otherwise the incoming packed is remarked no matter what dscp value it has. I didn’t find another way yet to solve this without the trust dscp command.
