Hi All
we have two N56128 and DELL BladeSwitche MXL 10/40
I tried to connect the MXL Switch to the Nexus by VPC (2 x 40GBit) via Cisco QSFP-H40G-CU5M cable.
N5K----N5K
MXL
Unfortunately I don't get any active links. The interfaces on both sides remain in status down.
Is there a special setting on the Nexus to use the QSFP-H40G-CU5M?
The cables on both switches are detected
Nexus
Ethernet1/49
transceiver is present
type is QSFP-H40G-CU5M
name is CISCO-JPC
part number is P3007U305000-1
revision is A0
serial number is JPC22170ETT-B
nominal bitrate is 10300 MBit/sec
Link length supported for copper is 5 m
cisco id is --
cisco extended id number is 16
MXL
LEJ-RZE-SW-BC1-A2#sh int fo 0/37 transceiver
Interface Name : fortyGigE 0/37
QSFP 37 Serial ID Base Fields
QSFP 37 Id = 0x0d
QSFP 37 Ext Id = 0x10
QSFP 37 Connector = 0x23
QSFP 37 Transceiver Code = 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00
QSFP 37 Encoding = 0x05
QSFP 37 Length(SFM) Km = 0x00
QSFP 37 Length(OM3) 2m = 0x00
QSFP 37 Length(OM2) 1m = 0x00
QSFP 37 Length(OM1) 1m = 0x00
QSFP 37 Length(Copper-1m/AOC-1m/OM4-2m) = 0x05
QSFP 37 Vendor Rev = A0
QSFP 37 Laser Wavelength = 115.90 nm
QSFP 37 CheckCodeBase = 0x66
QSFP 37 Serial ID Extended Fields
QSFP 37 BR max = 0
QSFP 37 BR min = 0
QSFP 37 Vendor SN = JPC22170ETT-A
QSFP 37 Datecode = 180425
QSFP 37 CheckCodeExt = 0xc8
QSFP 37 Extended Transceiver Code = 0x00
Does anyone have any experience with this type of cable?
Thanks Peter
