Hello, I have two Nexus 7000 in a VPC settings. After restarting one of them, VPC services stopped working and servers experienced a traffic cut in their LAN cards. I used the domain command "Reload Restore" in version 5.1, but the problem persists. Any ideas? Thanks.
Pablo.
Hi - please add
"sh run vpc" and "sh vpc" to see in what state are the links.
Alex
NX-CCSS-1# sho run vpc
!Command: show running-config vpc
!Time: Mon May 7 15:15:41 2012
version 5.0(5)
feature vpc
vpc domain 1
role priority 16380
system-priority 16384
peer-keepalive destination 172.31.100.2 source 172.31.100.1 vrf VPC-KA
reload restore delay 600
interface port-channel11
vpc peer-link
interface port-channel100
vpc 100
interface port-channel101
vpc 101
interface port-channel102
vpc 102
interface port-channel135
vpc 135
NX-CCSS-1# sho vpc
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 1
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is alive
Configuration consistency status: success
Type-2 consistency status : success
vPC role : primary, operational secondary
Number of vPCs configured : 32
Peer Gateway : Disabled
Dual-active excluded VLANs : -
vPC Peer-link status
id Port Status Active vlans
1 Po11 up 409-410,412-414,416-418,420-421,432-434,450-452,462,471,501,504,512,517,532-533
vPC status
id Port Status Consistency Reason Active vlans
100 Po100 up success success 433
102 Po102 up success success 433
103 Po103 up success success 433
104 Po104 up success success 433
105 Po105 up success success 433
106 Po106 up success success 433
107 Po107 up success success 433
108 Po108 up success success 433
109 Po109 up success success 433
110 Po110 up success success 434
111 Po111 up success success 434
112 Po112 up success success 452
113 Po113 up success success 432
114 Po114 up success success 432
115 Po115 up success success 432
116 Po116 up success success 432
117 Po117 up success success 432
121 Po121 up success success 412,414,416-417,451
123 Po123 up success success 412,414,416-417,451
125 Po125 up success success 412,414,416-417,451
126 Po126 up success success 412,414,416-417,451
127 Po127 up success success 412,414,416-417,451
129 Po129 up success success 412,414,416-417,451
130 Po130 up success success 412,414,416-417,451
131 Po131 up success success 412,414,416-417
132 Po132 up success success 412,414,416-417
134 Po134 up success success 413,418
135 Po135 up success success 409-410,501,504
From this outputs seems like vpc is fine.
Is the problem still observed on this chassis?
Check "show logging log" for possible reasons of traffic cut. Also I would suggest you to open a TAC case asap - because it would be difficult to troubleshoot iafter some time.
Alex
I will.
Thanks Alex.
If you can, you can follow the case. The number is:SR 621610513
Pablo.
I will follow it.
I see that you already got experienced engineer assigned to the service request - I'm sure the issue will be resolved soon.
Alex
