808
Send Sflow more than one agent ip -collector
Hi Dear How send Sflow to more than Ip address
In switch Config only define one sflow ip-collector
How send two or more Collector my sflow Data  ????
1 ACCEPTED SOLUTION
Sergiu.Daniluk
VIP Advisor
Hi admin@atrinnet.net
According to configuration guide, only one collector is supported:
The switch supports only one sFlow collector.
Reference:  https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/sw/system_mgmt/7_x/b_Cisco_Nexus_3000_Series_NX-OS_System_Management_Configuration_Guide_7x/b_Cisco_Nexus_3000_Series_NX-OS_System_Management_Configuration_Guide_7x_chapter_010110.ht...
This apply for both N3K and N9K switches.
Best regards,
Sergiu
5 REPLIES 5
balaji.bandi
VIP Guru
have you tried like below : (not tried checking is this accepting ?
sflow collector-ip 10.10.10.1 vrf xxxx
sflow collector-ip 10.10.10.2 vrf xxxx
BB
I used this
sflow collector-ip 10.10.10.1 vrf default
sflow collector-ip 10.10.10.2 vrf default
But switch Can get one destnation For Collector ip
Donnot send to two dst sflow data
i look at the document -
- The switch supports only one sFlow collector.
(May that destination one can send to other one) - just an iade
Device send to colelctor 1  - Collector can send to other collector - not good one but possible.
Like Agrigator - and Aggrigator send to different collector kind of ?
BB
Sergiu.Daniluk
VIP Advisor
Best regards,
Sergiu
Thank you For attention
You think i have this Config
feature sflow sflow sampling-rate 5000 sflow max-sampled-size 200 sflow counter-poll-interval 100 sflow max-datagram-size 2000 sflow collector-ip 192.0.2.5 vrf management (PRTG For see Flow Detail )
sflow collector-ip 192.0.2.6 vrf management (Fastnetmon For Detect DDOS)
sflow collector-port 7000 sflow agent-ip 192.0.2.3
But in switch i set one Collector -ip (Do not set 2 Destanation For Send Sflow Data)
How solve this ??? Send sflow Data two Destanation PRTG and Fastnetmon ?????
