Showing results forĀ
Search instead forĀ
Did you mean:Ā
Should I upgrade OS drivers prior to upgrade UCS Firmware?
I am planing to upgrade UCS B200 M2 and M3 servers, Infrastucture Firmware and UCS Manager Software. Most of the systems are RHEL but we also have Windows and some VMware servers. I am thinking of going to version 2.2(8i). Most of the firmwares are 2.1(3a) but there are also some older  2.1(2a)   2.0(1t)  and  1.4(2b).  The Fabric Interconnects are in cluster. Should I consider upgrading the OS drivers manyally one by one before upgrading the overall firmwares? The reason that I am doing this firmware is the lost of hard drives without any notification, I think it has something with the RAID driver. Thank you!
0 Replies 0
