02-27-2017 02:13 AM - edited 03-01-2019 08:30 AM
Hi community
I have installed successfully the CISCO Prime Infrastructure 3.1 from the OVA template.
The VMware Tools are installed and up to date but not running.
How can I start the VMware tools (without root access)?
Thank you
Solved! Go to Solution.
03-09-2017 09:12 AM
Greetings.
You may need to open a TAC case, but other similar cases indicated the following is generally required for this issue:
Execute the vmware-config-tools.pl script (from inside the RHEL guestVM) to update the initramfs/initrd
#sudo vmware-config-tools.pl
Kirk...
03-09-2017 09:12 AM
Greetings.
Kirk...
03-09-2017 09:12 AM
Thank you Kirk, now it is working!
P.S.: I needed to run it with sudo vmware...
03-27-2017 08:30 PM
Hi guys, sorry to hijack your thread but how did you run this command? I can log into the console of the appliance as admin but get very limited access???
03-27-2017 11:26 PM
Hi Tony, it's normal that the access is limited, but this command should works (at least it worked for me):
03-28-2017 02:53 PM
Thanks for that, yes that worked fine and now the tools are configured and working.
