451
Highlighted
Beginner
Sub-interfaces on n5k
Hi, I am trying to connect N5k (layer-3) and ASA, there is a requirement where some of the security-sensitive vlans have their layer-3 on the ASA and for those vlans who are less-sensitive have their svis on the N5k. I am doing a POC in my lab gear first. The n5k and the ASA are connected by 1 physical link having sub-interfaces on both the ends. There is a sub-int with vlan 10 (10.1.1.0/30) on both sides and the ASA injects a default-route to the N5k over this. so in case a non-secure vlan needs to talks to a secure-vlan it goes through via this path. My issue is that, if i create a sub-intf on the ASA, give it a vlan tag of 20, and on my N5k i add a port in that same vlan, i cannot ping my GW (ASA) from the laptop. I have also created a similar sub-int on the N5k side as well with tag 20, BUT still does not work.
attached visio.
Any clues??
Thnx
Sandev
Everyone's tags (2)
Content for Community-Ad
August's Community Spotlight Awards
