Supported DCI in NX9K-EX in small DCs
faizalis
Beginner
Beginner
we have same (just a proxy)app running in two diff DC's and needs to be connected using a effective solution. customer have black fibers and we are reluctant to just use a layer 2 trunk or Layer 3 (what if we miss any layer 2 traffic).
We are looking to have single pair of N9K switches in each DC to connect segmented servers with firewalls and SLB as front end. The switch will provide L2 segmentation and L3 aggregation using VRF(acts like a composed access/dist/core) and Firewall will be used for inter segment routing.
Is it possible to use VXLAN-EVPN in the same switches that connects rest of the devices and extend only VLANs that may require extensions. or simple VPC will work with any additional measures to avoid l2 limitaions.
Rick1776
Contributor
Contributor
Please also pay attention to the hardware limitations that support VxLAN in NX-OS mode.
jkilleda
Participant
Participant
Hi Faisal,
VXLAN-EVPN is a good solution for this senario , although Nexus 9k supports VPC but it is not recommended .
Recognize Your Peers
