UCS N20-C6508 chassis with Hardware Revision 0
Roney Daniel
Hello, I would like to check if the following chassis is fully supported with newer FIs such as 6454. The concern is about Hardware Revision 0. As per 6400 series FI spec, Cisco UCS 5108 rev 1 and rev 2 chassis are both supported with FI 6454 and 64108 however there is no reference to N20-C6508 with Hardware revision 0.
Model: N20-C6508
Part Number: 68-3231-01
VID: V01
HW Revision: 0
Mfg Date: 2009-04-01T01:00:00.000
Many Thanks,
Roney
0 Replies 0
