VDC License LAN_ADVANCED_SERVICES_PKG (N7K-ADV1K9) "Unused" ?
Currently I have a pair of Nexus 7009 with OS 6.1(2), FAB-2 & SUP2 with the following licenses output:
Feature                      Ins  Lic   Status Expiry Date Comments
                                 Count
MPLS_PKG                      No    -   Unused             -
STORAGE-ENT                   No    -   Unused             -
VDC_LICENSES                  No    0   Unused             -
ENTERPRISE_PKG                No    -   Unused             -
FCOE-N7K-F132XP               No    0   Unused             -
FCOE-N7K-F248XP               No    0   Unused             -
ENHANCED_LAYER2_PKG           No    -   Unused             -
SCALABLE_SERVICES_PKG         No    -   Unused             -
TRANSPORT_SERVICES_PKG        No    -   Unused             -
LAN_ADVANCED_SERVICES_PKG     Yes   -   Unused Never       -
LAN_ENTERPRISE_SERVICES_PKG   Yes   -   In use Never       -
The strange thing here is that i am currently using the 7K with 2 active vDCs. However the output shows that the LAN_ADVANCED_SERVICES_PKG is in "Unused" status.
Is this status correct? Why is not showing me as"In use" status?
InayathUlla Sharieff
Have you enabled the LAN_ADVANCED_SERVICES_PKG  license? try using grace period and see or if you have valid license file reenable it and check.
Inayath
License Is not using grace period, should show that on comments or expiry date.
I have no grace period alerts popping up either.
VDC#1 has no interfaces allocated. VDC#2 has all interfaces allocated.
Weird thing is that both VDCs are enabled and up and running.
Cant it be possible that VDC#1 is the default VDC and having no interfaces allocated cannot be considered as production VDC ?
even i see that "feature vdc" is not configured on the device....and "no system admin-vdc" is configured.
So i understand I have enabled the LAN_ADVANCED_SERVICES_PKG  license, or should be a command to check or enable it?
CK
glauber.bolzan
Beginner
Beginner
Try "show license usage vdc-all". I'm using OTV license, but when I try the command without "vdc-all" I see "Unused" for TRANSPORT_SERVICES_PKG.
Recognize Your Peers
