I am running into a problem were one of my VDCs (vdc 2) will not load on either of the dual sups I have in my chassis. It looks to be stuck in a "Create Pending" state. The only log that shows up that may be relevant is:
7K01 %$ VDC-1 %$ %CMPPROXY-2-LOG_CMP_IS_NOT_UP: Connectivity Management processor (on module 5) did not come up.
I'm guessing there is something wrong with the CMP?
#show hardware
CMP (Module 5) no response
CMP (Module 6) ok
I've tried re-seating each supervisor, failing over supervisors with no luck. I've also tried to boot the 7K with either / or SUP installed with the same results. Has anyone run into this issue and / or knows what the problem may be?
Thanks.
