07-23-2012 12:34 AM - edited 03-01-2019 07:08 AM
I have 2 SUN 4270 M2 servers connected with Nexus 5548 switch over 10Gb fiber card. I am getting performance of just 60 MB per second while transfer of 5Gb file across 2 servers. The similar speed i use to get on 1Gb network also. Please suggest how to improve the tranfer speed. On servers, ports ET4 and ETH5 are bonded in bond0 with mode=1. The server envrionment will be used for OVS 2.2.2.
Below are the details of network configuration on server. I quick help will be highly appriciated--
[root@host1 network-scripts]# ifconfig eth4
eth4 Link encap:Ethernet HWaddr 90:E2:BA:0E:22:4C
UP BROADCAST RUNNING SLAVE MULTICAST MTU:9000 Metric:1
RX packets:5648589 errors:215 dropped:0 overruns:0 frame:215
TX packets:3741680 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:2492781394 (2.3 GiB) TX bytes:3911207623 (3.6 GiB)
[root@host1 network-scripts]# ifconfig eth5
eth5 Link encap:Ethernet HWaddr 90:E2:BA:0E:22:4C
RX packets:52961 errors:215 dropped:0 overruns:0 frame:215
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3916644 (3.7 MiB) TX bytes:0 (0.0 b)
[root@host1 network-scripts]# ethtool eth4
Settings for eth4:
Supported ports: [ FIBRE ]
Supported link modes: 1000baseT/Full
Supports auto-negotiation: Yes
Advertised link modes: 1000baseT/Full
10000baseT/Full
Advertised auto-negotiation: Yes
Speed: 10000Mb/s
Duplex: Full
Port: FIBRE
PHYAD: 0
Transceiver: external
Auto-negotiation: on
Supports Wake-on: d
Wake-on: d
Current message level: 0x00000007 (7)
Link detected: yes
[root@host1 network-scripts]# ethtool eth5
Settings for eth5:
10000baseT/Full
Speed: 10000Mb/s
Duplex: Full
Port: FIBRE
PHYAD: 0
Supports Wake-on: d
Wake-on: d
Link detected: yes
[root@host1 network-scripts]# cat /proc/net/bonding/bond0
Ethernet Channel Bonding Driver: v3.2.4 (January 28, 2008)
Bonding Mode: fault-tolerance (active-backup)
Primary Slave: None
Currently Active Slave: eth4
MII Status: up
MII Polling Interval (ms): 100
Up Delay (ms): 0
Down Delay (ms): 0
Slave Interface: eth4
MII Status: up
Link Failure Count: 0
Permanent HW addr: 90:e2:ba:0e:22:4c
Slave Interface: eth5
MII Status: up
Permanent HW addr: 90:e2:ba:0e:22:4d
[root@host1 network-scripts]# modinfo ixgbe | grep ver
filename: /lib/modules/2.6.18-128.2.1.4.44.el5xen/kernel/drivers/net/ixgbe/ixgbe.ko
version: 3.9.17-NAPI
description: Intel(R) 10 Gigabit PCI Express Network Driver
srcversion: 31C6EB13C4FA6749DF3BDF5
vermagic: 2.6.18-128.2.1.4.44.el5xen SMP mod_unload Xen 686 REGPARM 4KSTACKS gcc-4.1
[root@host1 network-scripts]#brctl show
bridge name bridge id STP enabled interfaces
vlan301 8000.90e2ba0e224c no bond0.301
vlan302 8000.90e2ba0e224c no vif1.0
bond0.302
vlan303 8000.90e2ba0e224c no bond0.303
vlan304 8000.90e2ba0e224c no bond0.304
[root@host2 test]# ifconfig eth5
eth5 Link encap:Ethernet HWaddr 90:E2:BA:0F:C3:15
RX packets:4416730 errors:215 dropped:0 overruns:0 frame:215
TX packets:2617152 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:190977431 (182.1 MiB) TX bytes:3114347186 (2.9 GiB)
[root@host2 network-scripts]# ifconfig eth4
eth4 Link encap:Ethernet HWaddr 90:E2:BA:0F:C3:15
RX packets:28616 errors:3 dropped:0 overruns:0 frame:3
TX packets:424 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:4982317 (4.7 MiB) TX bytes:80029 (78.1 KiB)
[root@host2 test]#
[root@host2 network-scripts]# ethtool eth4
Settings for eth4:
10000baseT/Full
Speed: 10000Mb/s
Duplex: Full
Port: FIBRE
PHYAD: 0
Supports Wake-on: d
Wake-on: d
Link detected: yes
[root@host2 test]# ethtool eth5
Settings for eth5:
10000baseT/Full
Speed: 10000Mb/s
Duplex: Full
Port: FIBRE
PHYAD: 0
Supports Wake-on: d
Wake-on: d
Link detected: yes
[root@host2 network-scripts]# cat /proc/net/bonding/bond0
Primary Slave: None
Currently Active Slave: eth5
MII Status: up
Up Delay (ms): 0
Down Delay (ms): 0
MII Status: up
Permanent HW addr: 90:e2:ba:0f:c3:14
MII Status: up
Permanent HW addr: 90:e2:ba:0f:c3:15
[root@host2 network-scripts]# modinfo ixgbe | grep ver
[root@host2 network-scripts]#brctl show
vlan301 8000.90e2ba0fc315 no bond0.301
vlan302 8000.90e2ba0fc315 no bond0.302
vlan303 8000.90e2ba0fc315 no bond0.303
vlan304 8000.90e2ba0fc315 no vif1.0
bond0.304
Thanks....
Jay
07-23-2012 04:04 PM
On the Nexus, do you see any "Output Drops" or "Pause" frames incrementing?
07-24-2012 07:44 AM
Thanks for response...
On Nexus, there is no Output Drops or Pause, but errors count is increasing when i transfer some data from one host to other host through nexus. Even on my server also, error count is increasing as below--
#ifconfig eth5
RX packets:5883257 errors:12 dropped:0 overruns:0 frame:12
TX packets:6660592 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3591022675 (3.3 GiB) TX bytes:1306712675 (1.2 GiB)
Jay.
07-24-2012 03:23 PM
RX errors of that size is insignificant to the amount of total packets received. But I'd still be worried though.
07-30-2012 05:51 AM
Thanks for reply..but the RX errors count is keep on increasing and the transfer speed between 2 servers are max 60MB/ps on 10GB FC card. Even on storage also, i am getting the same speed when i try to transfer data from server to storage on 10GB FC card. Servers and storage are connected through Nexus 5548 switch.
#ifconfig eth5
RX packets:21187303 errors:1330 dropped:0 overruns:0 frame:1330
TX packets:17805543 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:624978785 (596.0 MiB) TX bytes:2897603160 (2.6 GiB)
JP
