Very low transfer speed issue on SUN4270 M2 server connected with nexus 5548 switch on 10GB fiber.
jayprakashk
I have 2 SUN 4270 M2 servers connected with Nexus 5548 switch over 10Gb fiber card. I am getting performance of just 60 MB per second while transfer of 5Gb file across 2 servers. The similar speed i use to get on 1Gb network also. Please suggest how to improve the tranfer speed. On servers, ports ET4 and ETH5 are bonded in bond0 with mode=1. The server envrionment will be used for OVS 2.2.2.
Below are the details of network configuration on server. I quick help will be highly appriciated--
[root@host1 network-scripts]# ifconfig eth4
eth4      Link encap:Ethernet  HWaddr 90:E2:BA:0E:22:4C
          UP BROADCAST RUNNING SLAVE MULTICAST  MTU:9000  Metric:1
          RX packets:5648589 errors:215 dropped:0 overruns:0 frame:215
          TX packets:3741680 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:2492781394 (2.3 GiB)  TX bytes:3911207623 (3.6 GiB)
[root@host1 network-scripts]# ifconfig eth5
eth5      Link encap:Ethernet  HWaddr 90:E2:BA:0E:22:4C
          RX packets:52961 errors:215 dropped:0 overruns:0 frame:215
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:3916644 (3.7 MiB)  TX bytes:0 (0.0 b)
[root@host1 network-scripts]# ethtool eth4
Settings for eth4:
        Supported ports: [ FIBRE ]
        Supported link modes:   1000baseT/Full
        Supports auto-negotiation: Yes
        Advertised link modes:  1000baseT/Full
                                10000baseT/Full
        Advertised auto-negotiation: Yes
        Speed: 10000Mb/s
        Duplex: Full
        Port: FIBRE
        PHYAD: 0
        Transceiver: external
        Auto-negotiation: on
        Supports Wake-on: d
        Wake-on: d
        Current message level: 0x00000007 (7)
        Link detected: yes
[root@host1 network-scripts]# ethtool eth5
Settings for eth5:
                                10000baseT/Full
        Speed: 10000Mb/s
        Duplex: Full
        Port: FIBRE
        PHYAD: 0
        Supports Wake-on: d
        Wake-on: d
        Link detected: yes
[root@host1 network-scripts]# cat /proc/net/bonding/bond0
Ethernet Channel Bonding Driver: v3.2.4 (January 28, 2008)
Bonding Mode: fault-tolerance (active-backup)
Primary Slave: None
Currently Active Slave: eth4
MII Status: up
MII Polling Interval (ms): 100
Up Delay (ms): 0
Down Delay (ms): 0
Slave Interface: eth4
MII Status: up
Link Failure Count: 0
Permanent HW addr: 90:e2:ba:0e:22:4c
Slave Interface: eth5
MII Status: up
Permanent HW addr: 90:e2:ba:0e:22:4d
[root@host1 network-scripts]# modinfo ixgbe | grep ver
filename:       /lib/modules/2.6.18-128.2.1.4.44.el5xen/kernel/drivers/net/ixgbe/ixgbe.ko
version:        3.9.17-NAPI
description:    Intel(R) 10 Gigabit PCI Express Network Driver
srcversion:     31C6EB13C4FA6749DF3BDF5
vermagic:       2.6.18-128.2.1.4.44.el5xen SMP mod_unload Xen 686 REGPARM 4KSTACKS gcc-4.1
[root@host1 network-scripts]#brctl show
bridge name     bridge id               STP enabled     interfaces
vlan301         8000.90e2ba0e224c       no              bond0.301
vlan302         8000.90e2ba0e224c       no              vif1.0
                                                        bond0.302
vlan303         8000.90e2ba0e224c       no              bond0.303
vlan304         8000.90e2ba0e224c       no              bond0.304
[root@host2 test]# ifconfig eth5
eth5      Link encap:Ethernet  HWaddr 90:E2:BA:0F:C3:15
          RX packets:4416730 errors:215 dropped:0 overruns:0 frame:215
          TX packets:2617152 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:190977431 (182.1 MiB)  TX bytes:3114347186 (2.9 GiB)
[root@host2 network-scripts]# ifconfig eth4
eth4      Link encap:Ethernet  HWaddr 90:E2:BA:0F:C3:15
          RX packets:28616 errors:3 dropped:0 overruns:0 frame:3
          TX packets:424 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:4982317 (4.7 MiB)  TX bytes:80029 (78.1 KiB)
[root@host2 test]#
[root@host2 network-scripts]# ethtool eth4
Settings for eth4:
                                10000baseT/Full
        Speed: 10000Mb/s
        Duplex: Full
        Port: FIBRE
        PHYAD: 0
        Supports Wake-on: d
        Wake-on: d
        Link detected: yes
[root@host2 test]# ethtool eth5
Settings for eth5:
                                10000baseT/Full
        Speed: 10000Mb/s
        Duplex: Full
        Port: FIBRE
        PHYAD: 0
        Supports Wake-on: d
        Wake-on: d
        Link detected: yes
[root@host2 network-scripts]# cat /proc/net/bonding/bond0
Primary Slave: None
Currently Active Slave: eth5
MII Status: up
Up Delay (ms): 0
Down Delay (ms): 0
MII Status: up
Permanent HW addr: 90:e2:ba:0f:c3:14
MII Status: up
Permanent HW addr: 90:e2:ba:0f:c3:15
[root@host2 network-scripts]# modinfo ixgbe | grep ver
[root@host2 network-scripts]#brctl show
vlan301         8000.90e2ba0fc315       no              bond0.301
vlan302         8000.90e2ba0fc315       no              bond0.302
vlan303         8000.90e2ba0fc315       no              bond0.303
vlan304         8000.90e2ba0fc315       no              vif1.0
       bond0.304
Thanks....
Jay
Leo Laohoo
On the Nexus, do you see any "Output Drops" or "Pause" frames incrementing?
Thanks for response...
On Nexus, there is no Output Drops or Pause, but errors count is increasing when i transfer some data from one host to other host through nexus. Even on my server also, error count is increasing as below--
#ifconfig eth5
          RX packets:5883257 errors:12 dropped:0 overruns:0 frame:12
          TX packets:6660592 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:3591022675 (3.3 GiB)  TX bytes:1306712675 (1.2 GiB)
Jay.
RX errors of that size is insignificant to the amount of total packets received.   But I'd still be worried though.
Thanks for reply..but the RX errors count is keep on increasing and the transfer speed between 2 servers are max 60MB/ps on 10GB FC card. Even on storage also, i am getting the same speed when i try to transfer data from server to storage on 10GB FC card. Servers and storage are connected through Nexus 5548 switch.
#ifconfig eth5
          RX packets:21187303 errors:1330 dropped:0 overruns:0 frame:1330
          TX packets:17805543 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:624978785 (596.0 MiB)  TX bytes:2897603160 (2.6 GiB)
JP
