09-05-2017 08:06 AM - edited 03-01-2019 08:37 AM
Hi ,
In my current scenario both firewalls are acting as Master/Slave and the L2 vlan extension is done via trunk between the two switches.Now i am in a situation where i have to migrate all the connections to N5K/N2K solution but the issue comes when firewall comes into picture as one vlan having HSRP running between DCs.The issue comes when we migrate the legacy infra to N5K/N2K solution as currenlty only two switches are paticipating in HSRP.Once we migrate HSRP will be running between all Four N5K.Need your suggestions whether we need to filter HSRP packets in OTV.But if we filters it then how the firewalls communicate/Sync with each other.Please share your suggestions.
Solved! Go to Solution.
10-05-2017 08:59 AM
10-05-2017 08:54 AM
10-05-2017 08:59 AM
