VLAN overlapping PHY and VMM domain
Jaya_tv
In the existing setup, I have VLAN-3 for both physical and virtual servers.
Once ACI comes into the picture is it possible to use the same ENCAP for both PHY and VMM domain in same EPG?
Example - Using encap  VLAN-3 static binding and VMM domain static allocation VLAN -3.
Francesco Molino
Yes you can have a physical domain and a VMM domain using the same encap within an EPG.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Sergiu.Daniluk
Hi @Jaya_tv
Yes you can use static vlan assignment for both phy and vmm domains.
Have a look at this thread regarding the static vlan allocation for VMM integration:
https://community.cisco.com/t5/application-centric/static-vlan-assignment-in-vmm-domain-intergration/td-p/2984912
Sergiu
