Vlan XLT Mapping
sanjumathen
Level 4
Level 4
While checking the VPC consistency for layer 1 on a port-channel interface, the output shows that "Vlan xlt mapping" is enabled in the peer and not locally.
However my vPC is up and this mismatch is not being treated as an inconsistency.
Since we are going to migrate a service to this new C7010 pair, just want to confirm what this feature really means and is it going to affect when traffic goes live,
BIOS:      version 2.12.0
kickstart: version 6.2(6)
system:    version 6.2(6)
Mod  Ports  Module-Type                                Model                    Status
1       24     10 Gbps Ethernet Module             N7K-M224XP-23L     ok
5       0       Supervisor Module-2                    N7K-SUP2E               active *
10     48     1/10 Gbps Ethernet Module          N7K-F248XP-25E     ok
sh vpc consistency-parameters vpc 527
    Legend:
        Type 1 : vPC will be suspended in case of mismatch
Name                        Type  Local Value            Peer Value
STP Port Type                       1     Default                Default
STP Port Guard                     1     Default                Default
STP MST Simulate PVST       1     Default                Default
lag-id                                      1     [(1, 0-23-4-ee-be-66,  [(1, 0-23-4-ee-be-66,
                                                      820f, 0, 0), (fa0,     820f, 0, 0), (fa0,
                                                      0-23-4-ee-be-1, 820f,  0-23-4-ee-be-1, 820f,
                                                      0, 0)]                 0, 0)]
mode                                     1     active                 active
Speed                                   1     10 Gb/s               10 Gb/s
Duplex                                   1     full                        full
Port Mode                             1     trunk                     trunk
Native Vlan                            1     1                          1
MTU                                      1     1500                   1500
LACP Mode                           1     on                     on
Interface type                        1     port-channel           port-channel
Admin port mode                    1     trunk                  trunk
Vlan xlt mapping                 1     Enabled                -
vPC+ Switch-id                      1     1001                   1001
vPC card type                        1     Clipper                Clipper
Allowed VLANs                       -
Local error VLANs                  -     -                      -
sanjumathen
Level 4
Level 4
Can anyone please guide on what vlan-xlt-mapping means on a vpc peer adjacency
I had the same problem.
not vlan translatio/mapping found on the second node.
Solution: removed vpc from port-channel and added vpc vom port-channel again.
