VPC between VDC's is this supported
kevinhobson2000
Hi all,
I have two 7K chassis running two VDC's and would like to run a VPC between them but i cant find any definitive answer if this is supported or not.
I have seen the slides on the cisco live presentation where it says that the VPC domains have to be different but i have seen no actual documentation that clearly says this is supported or not.
So it would be really appreciated if someone could confirm to me if this is supported or not.
Kev
sean_evershed
Level 7
Level 7
See this link for details
https://learningnetwork.cisco.com/docs/DOC-23972
Hi Sean,
First of all thanks for replying.
i have seen this link and others Referring to a single chassis which would be an spof.
But as I have two seperate chassis I do have redundancy at hw level but I do not see any verification on this.
cheers
Kev
i
