471
MGStickler
Beginner
VPC Failure When One N7K Down
Folks,
We had a situation where the VPCs failed on an active N7K when the other N7K was down. What can cause this? These VPCs are attached to non-Nexus devices so the VPC is only configured on the N7K.
1 REPLY 1
It depends on the failure type. Whether you lost the peer-keepalive, the peerlink, or both. There are different scenario's. Some of those the VPC secondary device will shut its VPC ports to prevent loops.
Sounds like your peerlink failed.
Again, i would recommend reading the following:
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/design_guide_c07-625857.pdf
hth
Content for Community-Ad
