11-21-2015 02:57 AM - edited 03-01-2019 08:05 AM
Hi all,
I have configure vpc bettewn two remote sites,with black fiber, and I was testing the L2 and I found that all the traffic goes only one way is not makeing any balance between divices.
Each 7700 has one conection to the other 7700.
Will this be normal?
Thanks.
11-22-2015 04:47 PM
LACP port channel is flow based load balancing. Depending on your load balancing algorithm (configurable) if you have one flow it will get hashed to one of the port channel members. The more flows you have (different source/destinations), the more "load balancing" you will achieve because of the more randomness of your flows means the output of the algorithm will hit other link(s).
11-23-2015 01:11 AM
hello ppalmerjr,
What will a god load balanc algorithm configuration be?
thanks.
11-24-2015 02:53 PM
I've always used the most specific method of loadbalancing. This way I would get the best load balancing as flows will use multiple links.
11-24-2015 03:39 PM
Hello
can you post your config?
thanks.
