11-05-2015 11:54 AM - edited 03-01-2019 08:05 AM
Hi all
I configured VPC between two nexus 5548p and two servers and I enable LACP in servers, the problem is not stable ping between tow servers each other a lot of request time out!! can you please review my configuration and tell me where is the wrong?attachment contain (show run/sh vpc brief/sh spanning-tree/sh port-channel summary) for each Nexus.
Many thanks
11-05-2015 01:21 PM
Add this to your config,
vrf context management
ip route 0.0.0.0/0 172.16.1.2
vpc domain 11
role priority 100
system-priority 4000
peer-keepalive destination 172.16.1.2 source 172.16.1.1
delay restore 60
peer-gateway
auto-recovery
11-05-2015 02:39 PM
thanks Aron for the reply, but the problem still and my nexus didnt support (peer-gateway) command!
11-06-2015 05:51 AM
Can you attach a show log from both N5ks?
Can you ping from the N5k to the server?
-AO
11-13-2015 02:48 AM
Can you publish sh vpc.
also check load-balancing algos on both servers and nexus switches to see if they are same.
