Ehsan M.
Beginner
vPC peer-link (F2e and F3 on each side)
Hi all,
I was wondering can I have vPC peer-link formed in the following configuration in Nexus 7000, NX-OS version 6.2(10):
F2e----------------F2e
F3-----------------F3
This is due to migration from F2e modules (where currently vPC peer-link is configured) to F3 modules on both ends.
3 REPLIES 3
sean_evershed
Rising star
My understanding is that it should work so long as the two switches pass the vPC consistency check:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/nx-os/interfaces/configuration/guide/b-Cisco-Nexus-7000-Series-NX-OS-Interfaces-Configuration-Guide/b-Cisco-Nexus-7000-Series-NX-OS-Interfaces-Configuration-Guide-6x_chapter_01000.html#concept_E56AEA7C0D824EBC952C052197D01C8C
Did some more research and found this guide. Appears that it is not supported.
Not Supported—Mixing I/O Modules on the Same Side of a Peer Link
Thanks Sean. I was hoping that since F3 line cards are only an enhancement to F2e series of line cards we can have them mixed for a few seconds (or minutes) in the bundle until we remove F2e's line cards out of the chassis and be running purely on F3 line cards.
Currently, vPC peer-link has been configured in a port-channel as follows:
F2e--------F2e
Content for Community-Ad
