05-15-2021 05:43 AM
I had to reboot the peer device(primary).After reboot all the interfac showing orange colour
How to fixthe issue
05-15-2021 10:11 AM
does the primary come back online? can you post below output from both the devices :
show vpc
show EtherChannel summary
show logg last 20 (from botht the switches)
show version
also check vpc troubleshoot guide:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/operations/n5k_vpc_ops.html
05-15-2021 06:40 PM
After shudown and start the peerlink shows amber (orange) color ,
Unfortunately there is only one peer-link available
here is the output of show vpc
vPC domain id : 100
Peer status : peer link is down
vPC keep-alive status : peer is alive
Configuration consistency status : failed
Per-vlan consistency status : success
Configuration inconsistency reason: Consistency Check Not Performed
Type-2 inconsistency reason : Consistency Check Not Performed
vPC role : none established
Number of vPCs configured : 4
Peer Gateway : Disabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Disabled (due to peer configuration)
Auto-recovery status : Disabled
Delay-restore status : Timer is off.(timeout = 30s)
Delay-restore SVI status : Timer is off.(timeout = 10s)
Operational Layer3 Peer-router : Disabled
Virtual-peerlink mode : Disabled
05-16-2021 02:00 AM
Configuration consistency status : failed Per-vlan consistency status : success Configuration inconsistency reason: Consistency Check Not Performed Type-2 inconsistency reason : Consistency Check Not Performed
as we have asked provide the configuration both devices.
show run
show vpc consistency-parameters vpc XX
show port-channel summary
05-16-2021 04:27 AM
Hi @susim
Actually the problem you have is due to peer-link being down:
Verify the interfaces part of the vpc peer-link port-channel are up. Once the peer-link will come up, the peer will take the appropriate vpc role and will bring up all interfaces.
Stay safe,
Sergiu
