vxlan multisite
vivarock12
  • Can VXLAN Multi site be done with only on border leaf?
Primary SITE
2 Spine and 4 Leaf
Secondary SITE
1 Spine and 2 Leaf
And im triying to have l2 redundancy.
Thanks for the help?
balaji.bandi
The solution is possible, again we are not sure your total environment. like topology and devices involved.
BB
Thanks for the help.
Primary Site:
2 - Border LEAF
2 - SPINE
2 - Clients LEAF
Secondary Site:
1 - Border LEAF:
1 - SPINE
1 - Clients LEAF
Border LEAF are for External Connection to the DC, And would be use for the BGW and should I user one for the Primary or both?
Clients LEAF for Server.
Question this will give me a Redundant L2 and L3
Saludos,
Gerardo Andree Mejia
here the topology al the nexus are Virtual machines on a VMware.
and the config is next:
SITE 1 spine
SPINE_SITE1# sh run
!Command: show running-config
!Running configuration last done at: Fri May 10 14:49:36 2019
!Time: Fri May 10 15:06:16 2019
version 9.2(3) Bios:version
hostname SPINE_SITE1
vdc SPINE_SITE1 id 1
limit-resource vlan minimum 16 maximum 4094
limit-resource vrf minimum 2 maximum 4096
limit-resource port-channel minimum 0 maximum 511
limit-resource u4route-mem minimum 128 maximum 128
limit-resource u6route-mem minimum 96 maximum 96
limit-resource m4route-mem minimum 58 maximum 58
limit-resource m6route-mem minimum 8 maximum 8
nv overlay evpn
feature ospf
feature bgp
feature pim
feature interface-vlan
feature vn-segment-vlan-based
feature nv overlay
username admin password 5 $5$WoQmtFHc$u5s4GMtkqKL2PMfpho6LQJmwCUwYkV.lGSwJpHUOAP
1 role network-admin
ip domain-lookup
system jumbomtu 9000
ip access-list a
10 permit ip 10.101.1.0 0.0.0.255 any
20 permit ip 10.101.12.0 0.0.0.255 any
evpn multisite border-gateway 101
delay-restore time 300
snmp-server user admin network-admin auth md5 0x51b17057bd12e6273fc6634ef5fa42c3
priv 0x51b17057bd12e6273fc6634ef5fa42c3 localizedkey
rmon event 1 description FATAL(1) owner PMON@FATAL
rmon event 2 description CRITICAL(2) owner PMON@CRITICAL
rmon event 3 description ERROR(3) owner PMON@ERROR
rmon event 4 description WARNING(4) owner PMON@WARNING
rmon event 5 description INFORMATION(5) owner PMON@INFO
fabric forwarding anycast-gateway-mac 0000.1111.2222
ip route 0.0.0.0/0 172.16.1.1
ip route 10.102.1.0/24 172.16.1.1 name EQUIPOS_DC2
ip route 10.102.12.0/24 172.16.1.1 name EQUIPOS_DC2
ip pim rp-address 10.101.1.1 group-list 224.0.0.0/4
ip pim ssm range 232.0.0.0/8
vlan 1,12,1001-1002
vlan 12
vn-segment 121212
vlan 1001
vn-segment 900001
vlan 1002
vn-segment 900002
route-map NEXT-HOP-UNCHANGED permit 10
set ip next-hop unchanged
route-map a permit 10
match ip address a
route-map unchanged permit 10
vrf context TENANT-BANRURAL
vni 121212
rd auto
address-family ipv4 unicast
route-target both auto
route-target both auto evpn
vrf context management
interface Vlan1
interface Vlan12
no shutdown
vrf member TENANT-BANRURAL
ip forward
interface nve1
no shutdown
host-reachability protocol bgp
source-interface loopback0
global mcast-group 239.0.0.1 L2
multisite border-gateway interface loopback3
member vni 121212 associate-vrf
member vni 900001
multisite ingress-replication
ingress-replication protocol bgp
member vni 900002
interface Ethernet1/1
description SPINE_SITE_XLEAF_SITE_1
no switchport
ip address 10.101.101.1/30
ip ospf network point-to-point
ip router ospf UNDERLAY_101 area 0.0.0.0
ip pim sparse-mode
evpn multisite fabric-tracking
no shutdown
interface Ethernet1/2
no switchport
ip address 172.16.1.2/30
ip router ospf DCI area 0.0.0.0
evpn multisite dci-tracking
no shutdown
interface mgmt0
vrf member management
interface loopback0
description Routing_ID_ANYCAST
ip address 10.101.1.1/32
ip pim sparse-mode
interface loopback1
description VTEP_ID
ip address 10.101.12.1/32
ip pim sparse-mode
interface loopback3
ip address 172.17.101.1/32
ip pim sparse-mode
line console
line vty
boot nxos bootflash:/nxos.9.2.3.bin
router ospf DCI
router-id 172.17.101.1
router-id 10.101.1.1
network 10.101.1.1/32 area 0.0.0.0
network 10.101.12.1/32 area 0.0.0.0
network 10.101.101.0/30 area 0.0.0.0
router bgp 65101
address-family l2vpn evpn
nexthop route-map unchanged
template peer VTEP-PEERS
remote-as 65101
update-source loopback0
send-community
send-community extended
route-reflector-client
send-community
neighbor 10.101.1.2
inherit peer VTEP-PEERS
neighbor 172.17.102.1
remote-as 65102
update-source loopback3
ebgp-multihop 5
peer-type fabric-external
send-community
rewrite-evpn-rt-asn
evpn
vni 900001 l2
rd auto
route-target import auto
route-target export auto
vni 900002 l2
rd auto
SITE1 LEAF
LEAF_SITE1# sh run
!Running configuration last done at: Fri May 10 14:36:40 2019
!Time: Fri May 10 15:09:38 2019
hostname LEAF_SITE1
vdc LEAF_SITE1 id 1
nv overlay evpn
feature ospf
feature bgp
feature pim
feature nv overlay
username admin password 5 $5$6aBohS/i$34DkDieA1YqeaGlG4SYKjdu9w9dOnWGwbY0Pupfkp.
6 role network-admin
ip domain-lookup
copp profile strict
snmp-server user admin network-admin auth md5 0x8ce9aeb2b012737f11b5990925534af0
priv 0x8ce9aeb2b012737f11b5990925534af0 localizedkey
ip route 0.0.0.0/0 10.101.101.1
ip route 10.102.1.0/24 10.101.101.1 name EQUIPOS_DC2
ip route 10.102.12.0/24 10.101.101.1 name EQUIPOS_DC2
vlan 1,12,1001-1002
vlan 12
vn-segment 121212
vlan 1001
vn-segment 900001
vlan 1002
vn-segment 900002
vni 121212
rd auto
interface Vlan1
interface Vlan12
no shutdown
ip forward
interface Vlan1001
no shutdown
ip address 192.168.120.1/24
fabric forwarding mode anycast-gateway
interface Vlan1002
no shutdown
ip address 192.168.121.1/24
interface nve1
no shutdown
member vni 900001
member vni 900002
no switchport
ip address 10.101.101.2/30
ip pim sparse-mode
no shutdown
switchport access vlan 1001
interface mgmt0
interface loopback0
ip address 10.101.1.2/32
ip pim sparse-mode
interface loopback1
description VTEP_ID
ip address 10.101.12.2/32
ip pim sparse-mode
line console
line vty
router ospf ISP_DCI
network 172.16.1.0/30 area 0.0.0.0
network 172.17.101.1/32 area 0.0.0.0
router-id 10.101.1.2
network 10.101.1.2/32 area 0.0.0.0
network 10.101.12.2/32 area 0.0.0.0
router bgp 65101
neighbor 10.101.1.1
remote-as 65101
send-community
send-community
vrf TENANT-BANRURAL
evpn
vni 900001 l2
rd auto
vni 900002 l2
rd auto
SITE2_spine
sITE2_SPINE# sh run
!Running configuration last done at: Fri May 10 14:48:46 2019
!Time: Fri May 10 15:06:20 2019
hostname SITE2_SPINE
vdc SITE2_SPINE id 1
nv overlay evpn
feature ospf
feature bgp
feature pim
feature nv overlay
username admin password 5 $5$GCQDA.HY$LDz1P9cPmzoij7ybOHbY1yo4lQZ0ly3HY5s.wEhYSc
ip domain-lookup
ip access-list a
10 permit ip 10.102.1.0 0.0.0.255 any
20 permit ip 10.102.12.0 0.0.0.255 any
copp profile strict
evpn multisite border-gateway 102
snmp-server user admin network-admin auth md5 0xf0bdbe1b1ed9d278f86e8659d0c681a2
priv 0xf0bdbe1b1ed9d278f86e8659d0c681a2 localizedkey
ip route 0.0.0.0/0 172.16.2.1
ip route 10.101.1.0/24 172.16.2.1 name EQUIPOS_DC1
ip route 10.101.12.0/24 172.16.2.1 name EQUIPOS_DC1
ip pim rp-address 10.102.1.1 group-list 224.0.0.0/4
vlan 1,12,1001-1002
vlan 12
vn-segment 121212
vlan 1001
vn-segment 900001
vlan 1002
vn-segment 900002
match ip address a
vni 121212
rd auto
interface Vlan1
interface Vlan12
no shutdown
ip forward
interface nve1
no shutdown
multisite border-gateway interface loopback4
member vni 900001
member vni 900002
no switchport
ip address 10.102.102.1/30
ip router ospf UNDERLAY_102 area 0.0.0.0
ip pim sparse-mode
no shutdown
no switchport
ip address 172.16.2.2/30
no shutdown
interface loopback0
ip address 10.102.1.1/32
interface loopback1
description VTEP ID
ip address 10.102.12.1/32
interface loopback4
ip address 172.17.102.1/30
ip pim sparse-mode
line console
line vty
router ospf DCI
router-id 172.17.102.1
router-id 10.102.1.1
network 10.102.1.1/32 area 0.0.0.0
network 10.102.102.0/30 area 0.0.0.0
router bgp 65102
remote-as 65102
send-community
send-community
neighbor 10.102.1.2
neighbor 172.17.101.1
remote-as 65101
update-source loopback4
ebgp-multihop 5
send-community
rewrite-evpn-rt-asn
evpn
vni 900001 l2
rd auto
vni 900002 l2
rd auto
SITE2_LEAF
SITE2_LEAF1# sh run
!Running configuration last done at: Fri May 10 14:31:35 2019
!Time: Fri May 10 15:09:33 2019
hostname SITE2_LEAF1
vdc SITE2_LEAF1 id 1
nv overlay evpn
feature ospf
feature bgp
feature pim
feature nv overlay
username admin password 5 $5$TkZisnlL$fjPNZWVKwqCvSfRC775jzVYrgXeq.8Dr4qZec9uXNj
9 role network-admin
ip domain-lookup
copp profile strict
snmp-server user admin network-admin auth md5 0x9f53aa2d952e6a7e7338e2e658c8c3dc
priv 0x9f53aa2d952e6a7e7338e2e658c8c3dc localizedkey
ip route 0.0.0.0/0 10.102.102.1
ip route 10.101.1.0/24 10.102.102.1 name EQUIPOS_DC1
ip route 10.101.12.0/24 10.102.102.1 name EQUIPOS_DC1
vlan 1,12,1001-1002,1021-1022
vlan 12
vn-segment 121212
vlan 1001
vn-segment 900001
vlan 1002
vn-segment 900002
vlan 1021
vn-segment 9000021
vlan 1022
vn-segment 9000022
vni 121212
rd auto
interface Vlan1
interface Vlan12
no shutdown
ip forward
interface Vlan1001
no shutdown
interface Vlan1002
no shutdown
interface Vlan1021
no shutdown
ip address 192.168.220.1/24
interface Vlan1022
no shutdown
ip address 192.168.221.1/24
interface nve1
no shutdown
member vni 900001
member vni 900002
member vni 9000021
member vni 9000022
no switchport
ip address 10.102.102.2/30
ip pim sparse-mode
no shutdown
interface loopback0
ip address 10.102.1.2/32
ip pim sparse-mode
interface loopback1
description VTEP_ID
ip address 10.102.12.2/32
ip pim sparse-mode
line console
line vty
router-id 10.102.1.2
network 10.102.1.2/32 area 0.0.0.0
network 10.102.12.2/32 area 0.0.0.0
router bgp 65102
neighbor 10.102.1.1
remote-as 65102
send-community
send-community
vrf TENANT-BANRURAL
evpn
vni 900001 l2
rd auto
vni 900002 l2
rd auto
vni 9000021 l2
rd auto
vni 9000022 l2
rd auto
