What VxLAN solved other than gives you plenty of VLAN more than 16 Million and Bridged L2 Traffic over IP Network
Ibrahim Jamil
Level 6
Level 6
Hi Guys
What VxLAN solved other than gives you plenty of VLAN more than 16 Million and Bridged L2 Traffic over IP Network so than we have VM  Mobility using Vmotion
thanks to all of you Guys
Ibrahim
Good Docs
VXLAN has the following benefits: • Flexible placement of multi tenant segments throughout the data center. It provides a way to extend Layer 2 segments over the underlying shared network infrastructure so that tenant workloads can be placed across physical pods in the data center. • Higher scalability to address more Layer 2 segments. VXLAN uses a 24-bit segment ID, the VXLAN network identifier (VNID). This allows a maximum of 16 million VXLAN segments to coexist in the same administrative domain. (In comparison, traditional VLANs use a 12-bit segment ID that can support a maximum of 4096 VLANs.) • Utilization of available network paths in the underlying infrastructure. VXLAN packets are transferred through the underlying network based on its Layer 3 header. It uses equal-cost multipath (ECMP) routing and link aggregation protocols to use all available paths.
thanks mate
