Highlighted
Enthusiast
Where did the Upgrade option go in HX Connect UI?
I have a brand new HX 3-node Edge cluster built with 4.0 but when I login to HX Connect, there is no Upgrade button on the left of page...Screenshot below.
Is it because the version running is the latest already? The cluster is healthy.
1 REPLY 1
Highlighted
Re: Where did the Upgrade option go in HX Connect UI?
It looks like you are connected to HX Connect via Intersight. If so, you won't see the upgrade button.
You can upgrade your HyperFlex Edge cluster via Intersight.
Go to the HyperFlex cluster view. On the right click on the ... (Three dots) of the cluster and now you can easily upgrade the cluster.
Not only are you able to upgrade HXDP, but also ESXi with Intersight.
Kind Regards,
Joost.
