wol packet from nexus 9k
k.adath2015
from server ( n9k,ip 192.168.1.10) want to send wol packets to the client . But N9k does not support the command ip helper address
clients are in
10.10.10.0/24
You say your testing app is on a different vlan from your target vlan so i will assume there is a layer3 device routing between them.
Enabling ip directed-broadcast on the L3 interface attached to the destination subnet should be done. It is advised to attach an ACL to the command also to limit it to certain hosts.
