2950 switches get stuck
michaelpolevoy
Lately we see a problem with some of our 2950 switches.
The switches get stuck, all the connected ports are lighten with constant light, althogh the machines generate traffic the light are not blinking.
the switches running with IOS version 12.1(19)EA1c
The only solution to this problem is to reboot it.
can someone give me a clue how to truobleshoot this problem.
TIA
is there any traffic passing between the attached devices when this occurs ? If so, the following bug might apply:
CSCdx39374 Bug Details
Utilization LED not display according to documentation
Defect description:
The LED in the utilization mode does not display according to the Hardware
Installation Guide.
Symptons:
There is not much difference in the LED utilization display when the traffic
being switched on a C2950 has increased or decreased significantly.
Assessment of the impact:
The symptom is minimal as it does not affect the functionality of the box.
Workaround:
The workaround is to upgrade the image to the 12.1(11)EA1 release.
Description of the expected behavior:
The LED in the utilization mode should display the bandwidth utilization of
the switch according to the Hardware Installation Guide
GP
