3640 NM-2FE2W card problem
yatao
Recently I upgraded a 3640 from 12.0.5 to 12.1.7, and notice that IOS doesn't regconize the NM-2FE2W card any more, it says "no iomem table entry for PA(0xD8) in slot0". run "show diag":
fwa>sh diag
Slot 0:
Unknown (type 216) Port adapter
Port adapter is disabled
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 1.0
Part Number : 800-04797-01
Board Revision : E0
Deviation Number : 0-0
Fab Version : 04
PCB Serial Number : JAB04130H1R
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 00 D8 41 01 00 C0 46 03 20 00 12 BD 01
0x10: 42 45 30 80 00 00 00 00 02 04 C1 8B 4A 41 42 30
0x20: 34 31 33 30 48 31 52 03 00 81 00 00 00 00 04 00
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
And this problem happens in another 3640 with 12.0.7. Anyone has idea what is the problem? How to fix it?
Yatao
srehan
You need to have 121.1T or later version and have ip plus feature set to support ISL trunking on fast ethernet. Send sh ver please
Thanks for your quick response. Here is the output:
IOS (tm) 3600 Software (C3640-JO3S56I-M), Version 12.1(7), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Fri 23-Feb-01 03:21 by kellythw
Image text-base: 0x60008940, data-base: 0x61442000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
fwa uptime is 2 hours, 7 minutes
System returned to ROM by reload
System image file is "flash:c3640-jo3s56i-mz.121-7.bin"
cisco 3640 (R4700) processor (revision 0x00) with 60416K/5120K bytes of memory.
Processor board ID 15636356
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
2 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
4 Serial network interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Could you recommend a IOS version?
Thanks again
Yatao
You need to upgrade the version in order to support that card , 12.1T or hight version in T train or if you want. to stay with main lin version then 12.2 will be okay .
