3725 with IP Base 12.3 doesn't accept encapsulation command - URGENT
g.quintin
We have replave a 3620 router by a 3725, but the configuration of the vlan doesn't work on the 3725 because it doesn't accept the encapsulation command following:
- encap dot1Q 1
- encap ISL
Here after is the Vlan configuration:
interface FastEthernet0/0
description VERS CLIENT-PACKET VLAN
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip accounting access-violations
duplex auto
speed auto
no cdp enable
interface FastEthernet0/0.2
description vers cyber express
bandwidth 64
encapsulation dot1Q 2
ip address 10.227.2.254 255.255.255.0
ip access-group 101 in
ip nat inside
Is there someone to help us?
Thanks.
It appears IP Base has it as well
3725#sh ver | include IOS
IOS (tm) 3700 Software (C3725-IPBASE-M), Version 12.3(15a), RELEASE SOFTWARE (fc2)
3725#conf t
Enter configuration commands, one per line. End with CNTL/Z.
3725(config)#int fas0/1.1
3725(config-subif)#encapsulation ?
dot1Q IEEE 802.1Q Virtual LAN
isl Inter Switch Link - Virtual LAN encapsulation
tr-isl Token Ring Inter Switch Link - Virtual LAN encapsulation
3725(config-subif)#end
3725#
*Mar 1 00:03:16.839: %SYS-5-CONFIG_I: Configured from console by console
3725#dir flash:
Directory of flash:/
1 -rw- 10914060 Mar 1 1993 02:13:10 +00:00 c3725-ipbase-mz.123-15a
31956992 bytes total (21041152 bytes free)
9 Replies 9
paddyxdoyle
Level 6
Level 6
I believe you need to be running the IP Plus feature set to support trunking.
PJD
I don't think that I need IP PLus feature because the "Cisco Features navigator Tool" valid that IP Base support ISL Vlan and IEEE802.1q with release 12.3.
Maybe the feature navigator is wrong with this one. Can you try a IP Plus image?
No, i can't try IP Plus Feature because the router 3725 is in another country.
How to know which feature to install if the tool is wrong?
I tried with IP Plus in lab and do see encapsulation options
3725-A#sh ver | include IOS
IOS (tm) 3700 Software (C3725-IS-M), Version 12.3(15a), RELEASE SOFTWARE (fc2)
3725-A#conf t
3725-A(config)#int fastEthernet 0/1.1
W2N-3.7-3725-A(config-subif)#encapsulation ?
3725-A(config-subif)#encapsulation dot1Q 1 native
3725-A(config-subif)#ip address 10.1.1.1 255.255.255.0
3725-A#dir flash:
1 -rw- 19584036 Mar 2 1993 02:36:40 +00:00 c3725-is-mz.123-15a
Please, Can you verify that IP Base support these options?
Not supported in IP Base..
3725#sh ver | inc IOS
IOS (tm) 3700 Software (C3725-I-M), Version 12.3(15a), RELEASE SOFTWARE (fc2)
3725#conf t
3725(config)#int fastEthernet 0/1.1
3725(config-subif)#e?
exit
3725#
*Mar 1 00:01:38.395: %SYS-5-CONFIG_I: Configured from console by console
3725#dir
1 -rw- 8832556 Mar 1 1993 20:13:58 +00:00 c3725-i-mz.123-15a
31956992 bytes total (23121920 bytes free)
3725#
Thanks for your answer, but it was on a IP Feature:
c3725-i-mz.123-15a => "i" seems "IP" feature only.
Can you make the test with "IP Base" Feature?
3725#conf t
3725#
3725#dir flash:
