4507 problem
mabadie
this is the sh intreface status
Gi3/1 notconnect 1 auto auto 10/100/1000-TX
Gi3/2 notconnect 1 auto auto 10/100/1000-TX
Gi3/3 notconnect 1 auto auto 10/100/1000-TX
Gi3/4 notconnect 1 auto auto 10/100/1000-TX
Gi3/5 notconnect 1 auto auto 10/100/1000-TX
Gi3/6 notconnect 1 auto auto 10/100/1000-TX
Gi3/7 notconnect 1 auto auto 10/100/1000-TX
Gi3/8 notconnect 1 auto auto 10/100/1000-TX
Gi3/9 notconnect 1 auto auto 10/100/1000-TX
Gi3/10 notconnect 1 auto auto 10/100/1000-TX
Gi3/11 notconnect 1 auto auto 10/100/1000-TX
Gi3/12 notconnect 1 auto auto 10/100/1000-TX
Gi3/13 notconnect 1 auto auto 10/100/1000-TX
Gi3/14 notconnect 1 auto auto 10/100/1000-TX
Gi3/15 notconnect 1 auto auto 10/100/1000-TX
Gi3/16 notconnect 1 auto auto 10/100/1000-TX
Gi3/17 faulty 1 auto auto 10/100/1000-TX
Gi3/18 faulty 1 auto auto 10/100/1000-TX
Gi3/19 faulty 1 auto auto 10/100/1000-TX
Gi3/20 faulty 1 auto auto 10/100/1000-TX
Gi3/21 notconnect 1 auto auto 10/100/1000-TX
Gi3/22 notconnect 1 auto auto 10/100/1000-TX
Gi3/23 notconnect 1 auto auto 10/100/1000-TX
Gi3/24 notconnect 1 auto auto 10/100/1000-TX
you can see that port 17,18,19 and 20 in a faulty status
so this is the diagnostics online
4507#show diagnostics online module 3
Slot Ports Card Type Diag Status Diag Details
3 24 10/100/1000BaseTX (RJ45) faulty None
Detailed Status
. = Pass U = Unknown
L = Loopback failure S = Stub failure
I = Ilc failure P = Port failure
E = SEEPROM failure G = GBIC integrity check failure
Ports 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
Ports 17 18 19 20 21 22 23 24
S S S S . . . .
I replaced the module to another slot and the module status is ok and ports 17,18,19,20 are ok
you think it is backplan problem
thanks
pflunkert
Level 4
Level 4
i don't think that this is a backplane problem. When the module will works in another slot without any error, it looks like a problem with the supervisor engine. Please post a show version and a show module. Had you seen any messages on the console?
Peter
Kevin Dorrell
Level 10
Level 10
It does seem that way. I suppose the ports access the backplane in groups of four ports, giving six x 1 Gbps backplane connections per card, which is consistent with what I know about other cards, e.g. WS-X4418.
On the other hand, I hear that the backplane is entirely passive - it's just a way of connecting cards into the Supervisor. That means it is more likely the Supervisor card is broken at the backplane interface.
When you put the card back in its original slot, does the fault come back?
Kevin Dorrell
Luxembourg
