7204 VXR reboots into ROM mode always
c.mac
Beginner
Beginner
Hi all,
I am having all sorts of problems with my 7204. For some strange reason it rebooted itself, but into ROM mode. Everytime I tried to reset it, it would tell me that the bootflash could not load cuz of some sort of error and revert back to ROM mode. Can anyone tell me how to fix this.
FYI: The only time I get the router to be stable is if I load a whole new IOS and keep the router powered on. Even after I have the new IOS loaded and do a reload, it will automatically give me the same problem and stay in ROM mode. Please anyone..HELP....
12 Replies 12
thisisshanky
Advisor
Advisor
Can you paste the error message, exactly as it reports. Probably your boot flash image is corrupt.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
deilert
Frequent Contributor
sounds like your box is crashing and when it is recovering the boot statements are incorrect. Paste in a sh ver and a sh run and a sh flash /dir slot0:
When I do a show flash I get
Open device slot0 failed (Device not ready)
For show version I get
IOS (tm) 7200 Software (C7200-IS-M), Version 12.2(11)T, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Fri 02-Aug-02 10:51 by ccai
Image text-base: 0x60008940, data-base: 0x61850000
ROM: System Bootstrap, Version 12.1(20000710:044039) [nlaw-121E_npeb 117], DEVEL
OPMENT SOFTWARE
JEH7204 uptime is 15 hours, 8 minutes
System returned to ROM by reload at 00:02:04 UTC Mon Mar 1 1993
System image file is "disk0:c7200-is-mz.122-11.T.bin"
cisco 7204VXR (NPE225) processor (revision A) with 114688K/16384K bytes of memor
y.
Processor board ID 23658225
R527x CPU at 262Mhz, Implementation 40, Rev 10.0, 2048KB L2 Cache
4 slot VXR midplane, Version 2.1
Last reset from s/w nmi
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
20 Serial network interface(s)
125K bytes of non-volatile configuration memory.
46976K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
4096K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x100 (will be 0x0 at next reload)
I think I have to change the confreg back to the normal setting. But need a second opinion.
This will happen only because of 2 reasons :
1) bootflash image not compatible with your flash image.
2) as shanky said, your bootflash might be corrupted.
DONT CHANGE THE BOOTFLASH IN ANY CASE, AS YOU MIGHT NEED TO CHANGE THE ENTIRE I/O CONTROLLER if anything goes wrong.
Hmm..okay I just tried a reload and this is exactly what I get.
System Bootstrap, Version 12.1(20000710:044039) [nlaw-121E_npeb 117], DEVELOPMEN
T SOFTWARE
Copyright (c) 1994-2000 by cisco Systems, Inc.
C7200 platform with 131072 Kbytes of main memory
T SOFTWARE
Checksum failed on c7200-fslib-m
Expected checksum: c32b, calculated checksum: 235b
open: file "c7200-fslib-m" not found
open(): Open Error = -1
loadprog: error - on file open
cannot load the monitor library "bootflash:%c7200-fslib-m" from device: boot fla
shboot: cannot open "bootflash:"
an alternate boot helper program is not specified
(monitor variable "BOOTLDR" is not set)
and unable to determine first file in bootflash
boot: cannot load "cisco2-C7200"
T SOFTWARE
string is disk0:c7200-is-mz.120-26.bin
Self decompressing the image : #################################################
################################################################## [OK]
*** Coprocessor Unusable Exception ***
PC = 0x87ff7820, Cause = 0x2000002c, Status Reg = 0x3040d003
monitor: command "boot" aborted due to exception
T SOFTWARE
boot: cannot determine first file name on device "bootflash:"
T SOFTWARE
I have no idea how to stop this madness..
deilert
This error
is telling me that either your image does not support your NPE or your image is corrupt
What kind of NPE are you running
it's a 7204 VXR with NPE 225
deilert
thanks , do you have a PCMCIA card on the box or do you have another box close that you can move the PCMCIA card from to get the box up ?
You can try to remove the PCMCIA card from slot0; then reboot the box will load the first valid file it sees in flash , if it can not find one it should load to bootflash.
I have tried that...it reverts back to this line
T SOFTWARE
and after 3 tries it goes into ROm ..
Now when I put back the card, which has the 122.T image it loads fine but I lose all my configs. When I force it to load from an image that i saved with all the configs on it gives me this error
I am really lost for words...have no idea what the fix is
deilert
Ok What is going on is you boot statements are bogus if you notice on the sh ver above it it loading disk0:c7200-is-mz.122-11.T.bin" from disk0: your boot statement is looking at slot0:
This leads me to beleive the image 12.0(26) is not high enough rev for an npe 225 . From the compatability matrix
What you can do here since there is a good image on the box is power cycle the box , when you get the ###### going across the screen break in to the box
then set your config register to 0x2142 this will ignore NVRAM and your boot statements. It should load the image on disk0:
rommon> confreg 0x2142
rommon> reset
after this you should get to
router>
router >en
hit enter
router # copy start run
router # conf t
router#(conf) no boot system
router#(conf) config-register 0x2102
router#(conf) end
router# copy run disk0:
router#wr
router# reload
7200 NPE-225=
Minimum Supported Software Release(s) per release train
12.0(5)XE6, 12.0(7)XE1, 12.0(9)S, 12.1(1)E, 12.1(1)T, 12.1(1), 12.1(14)E, 12.2(1), 12.2(2)T
I have tried that....I have no problems when I am loading the 122-11.T.bin image from disk0. But the issue I have is when I save my configs to disk0 and do a reload. The file with the running config will not load. So I am forced to redo all my configs after it loads the 122-11.T image.
deilert
All you need to do is a copy disk0:running-conf runn
this will copy the config you saved on the disk0: to the running config once this is done do a wr mem and it will be saved in NVRAM . Prior to saving to NVRAM make sure that you do not have a bogus boot statement in the running config. then do a reload and the box should come up ok
Recognize Your Peers
