10-11-2011 10:22 AM - edited 03-03-2019 06:23 AM
I have a 7606 running
c7600rsp72043-advipservicesk9-mz.122-33.SRD2.bin
with SIP-400 card that has suddenly stopped working, on checking the logs i see the following:
%ONLINE-SP-6-TIMER: Module 3, Proc. 0. Failed to bring online because of timer event
%C7600_PWR-SP-4-DISABLED: power to module in slot 3 set off (Module Failed SCP dnld)
I have tried reseating and even moving it to a different slot but no luck.
%ONLINE-SP-6-TIMER: Module 4, Proc. 0. Failed to bring online because of timer event
%C7600_PWR-SP-4-DISABLED: power to module in slot 4 set off (Module Failed SCP dnld)
sh module
Mod Ports Card Type Model Serial No.
1 20 ESM20G 7600-ES20-GE3C JAE1237UT90
2 4 7600 ES+ 7600-ES+4TG3CXL JAE13157HIW
3 0 4-subslot SPA Interface Processor-400 7600-SIP-400 JAE13219CZH
5 2 Route Switch Processor 720 (Active) RSP720-3C-GE JAE1151819I
6 2 Route Switch Processor 720 (Hot) RSP720-3C-GE JAE11495POH
Mod MAC addresses Hw Fw Sw Status
1 0023.5e2f.2a80 to 0023.5e2f.2aff 1.2 12.2(33r)SRB 12.2(33)SRD2 Ok
2 0024.f94d.2020 to 0024.f94d.202f 1.0 12.2(33r)SRD 12.2(33)SRD2 Ok
3 0025.8498.97c0 to 0025.8498.983f 2.7 Unknown Unknown Other
5 001b.d401.6a38 to 001b.d401.6a3b 5.2 12.2(33r)SRB 12.2(33)SRD2 Ok
6 0007.0e61.fbd0 to 0007.0e61.fbd3 5.2 12.2(33r)SRB 12.2(33)SRD2 MinFail
Mod Sub-Module Model Serial Hw Status
1 ESM20G/PFC3C Distributed Fo 7600-ES20-D3C JAE1239VRB1 1.0 Ok
1/0 10XGE Port 7600-ES20-20GE JAE1239VZJQ 1.1 Ok
1/1 10XGE Port 7600-ES20-20GE JAE1239VZJQ 1.1 Ok
2 7600 ES+ DFC XL 7600-ES+3CXL JAE1317820T 1.0 Ok
2 7600 ES+ 4x10GE XFP 7600-ES+4TG JAE131885HO 1.0 Ok
5 Policy Feature Card 3 7600-PFC3C JAE11506F4K 1.1 Ok
5 C7600 MSFC4 Daughterboard 7600-MSFC4 JAE115181EH 1.1 Ok
6 Policy Feature Card 3 7600-PFC3C JAE1148530L 1.1 MinFail
6 C7600 MSFC4 Daughterboard 7600-MSFC4 JAE11474CSM 1.1 MinFail
Mod Online Diag Status
1 Pass
1/0 Pass
1/1 Pass
2 Pass
3 Unknown
Anyone know of another way of resolving this?
Alfred
10-11-2011 01:50 PM
Hi Alfred,
have you tried to reload the module?
hw-module module 3 reset
you could also try to boot it up with different Sup as active, i.e after a switchover:
redundancy force-switchover
if possible, please try this module in a different chassis.
The troubleshooting could be a bit sophisticated, so it is wise to open a SR for that, though I'd recommend to go for a replacement right away.
Hope this helped a bit,
Ivan.
10-11-2011 08:05 PM
Hi Ivan,
I had tried to do the module reset but it made no difference.
On digging a little bit further i found that the box had rebooted due to a software reset just before the SIP-400 started having issues. Here is a snippet of the show stack comand
%CPU_MONITOR-3-PEER_EXCEPTION: CPU_MONITOR peer has failed due to exception , reset by [5/0]
%Software-forced reload
Unexpected exception to CPU: vector 1500, PC = 0xA7D3390 , LR = 0xA7D3330
-Traceback= A7D3390 A7D3330 A4DDA50 A370974 A3B1BB8 A3B1C24 89285F4 89297C0 892A5A0 A2697A8 A269F28 A81C1B0 A81C528 A81D9E0 A7C916C A87019C
Testing the SIP on a different chassis might be a problem but i'll try to force the router to boot with a different Sup and see if it helps.
Alfred.
10-12-2011 07:44 AM
Hi Alfred,
do you have any idea whether somebody was being doing something on that box, like issueing any show commands or configuration tasks before the issue?
I think we should have a crashinfo file(s) for that instance, please have a look at the router's storage locations - show bootdisk etc.
Cheers,
Ivan.
10-12-2011 10:04 AM
Hi Ivan,
I ended up trying the SIP on a different chassis and it didn't power up so we're getting a replacement.
We'll look at the crashinfo for any further clues but from the configuration archived logs nobody had been logged in to the router or done any config changes at the time of the crash.
Thank you very much for your assistance.
Alfred
