802.3ad connection from server to 2 switches
trunguyen
Beginner
Beginner
I am trying to find a solution for Windows-based server NIC connectivity redundancy using 2 different Cisco switches. The NIC mfg (Intel) states their NICs support dynamic 802.3ad, which allows the creation of a single EtherChanneling group from a server to 2 different switches. I have tried this in a lab environment & it does appear to work but can't find reference from Cisco to say it is supported. Does anyone know the answer to this or alternative Cisco-supported solution? Thanks. TN
khj1
Beginner
Beginner
hi
cisco equipment dont support etherchannel to different switches.
BR
Thanks for the reply. Does anyone know if this will be supported in the future? TN
