a couple of problems with c6k
frzhang
I got a problem with one of the c6ks with sup2 msfc2. When running native mode,we can access all the file system sup-bootflash, bootflash, slot0. We can see all the files in there. Also under rommon, we can see files in bootflash (sup-bootflash) and slot0. But when we run it in hybrid mode, we can see any files in bootflash (sup-bootflash) and slot0. It shows all empty. I have checked confreg etc. Zero configuration. Can't figure it out.
Another c6k, when we tried to load native ios, it stopped at switching control to rp, and entered rommon of rp. At that point, we could only see bootflash of rp.
Any thoughts on that? Thanks.
Prashanth Krishnappa
If you convert from Native IOS to hybrid, the file systems would have changed and you will need to format the flash device and TFTP the file again.
For the second issue, you cannot see the SP Bootflash from RP rommon, but the RP can still access it. So make sure you have the right file name and issue a "boot sup-bootflash:"
