Access List problem on 1841 IS
akalhan
Current configuration : 3904 bytes
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime !
hostname router1
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 debugging
enable secret 5 x
username admin privilege 15 secret 5 x
no aaa new-model
ip subnet-zero
no ip source-route
ip cef
ip tcp synwait-time 10
no ip bootp server
no ftp-server write-enable
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$$ES_LAN$$FW_INSIDE$
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
duplex auto
speed auto
no cdp enable
no mop enabled
interface FastEthernet0/1
description $ES_WAN$$FW_OUTSIDE$
ip address 216.240.x.a 255.255.255.0
ip access-group 101 in
ip access-group 100 out
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip route-cache flow
duplex auto
speed auto
no cdp enable
no mop enabled
interface Serial0/0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
shutdown
no cdp enable
ip default-gateway 216.240.x.x
ip classless
ip route 0.0.0.0 0.0.0.0 216.240.x.x
ip http server
ip http authentication local
ip http timeout-policy idle 600 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet0/1 overload
ip nat inside source static 192.168.1.10 216.240.x.b
ip nat inside source static 192.168.1.11 216.240.x.c
logging trap debugging
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 100 permit ip any any
access-list 101 permit gre any host 216.240.x.a
access-list 101 permit tcp any host 216.240.x.a eq telnet
access-list 101 permit tcp any host 216.240.x.a eq www
access-list 101 permit tcp any host 216.240.x.b eq 1723
access-list 101 permit tcp any host 216.240.x.b eq 443
access-list 101 permit tcp any host 216.240.x.b eq 47
access-list 101 permit tcp any host 216.240.x.b eq domain
access-list 101 permit tcp any host 216.240.x.b eq ftp
access-list 101 permit tcp any host 216.240.x.b eq ftp-data
access-list 101 permit tcp any host 216.240.x.b eq www
access-list 101 permit udp any host 216.240.x.b eq 1723
access-list 101 permit udp any host 216.240.x.b eq 47
access-list 101 permit udp any host 216.240.x.b eq domain
access-list 101 permit udp any host 216.240.x.c eq domain
access-list 101 permit tcp any host 216.240.x.c eq 443
access-list 101 permit tcp any host 216.240.x.c eq domain
access-list 101 permit tcp any host 216.240.x.c eq ftp
access-list 101 permit tcp any host 216.240.x.c eq ftp-data
access-list 101 permit tcp any host 216.240.x.c eq www
access-list 101 deny ip any any
no cdp run
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet
line vty 5 15
privilege level 15
login local
scheduler allocate 4000 1000
end
--------------------- PROBLEM ----------------------
I want users to be able to go out on every port and only selective ports open for incoming.
I thght the deny any ip ip is implicit.However if I dont give access-list 101 deny ip any any it lets everyone in.
the moment i state the deny it denies all outgoing traffic as well.
So i added the 101 deny and 102 incoming and it didnot work. what am i doing wrong.
Any help is really appreciated.
5 Replies 5
brianj
Access-lists can be applied in each direction. The direction is from the routers perspective. Therefore "IN" means coming into the router interface and "OUT" means leaving the router interface. When you apply an acl to an interface it is applied in the direction you specify. If you only want to control traffic coming into the router you should only need specify an inbound acl.
The use of access-list 100 is unnecessary. The deny statement at the end of access-list 101 is going to deny any traffic which was not implicitly allowed by previous permit statements. Therefore, it seems to be doing its job.
HTH,
Brian
Brian,
So if I want to send traffic to internet
access-list 101 192.168.1.0 0.0.0.255 any
that should work right
I am new to this and am trying to learn the ropes.
AK
You have your access-lists the right way round.
The problem is extended access lists aren't stateful, i.e. they explicitly permit or deny traffic based on the rules you create.
So when traffic leaves your network to its destination, it's permitted out to the internet via access-list 100. When it comes back into your network, the traffic is checked by access list 101.
So if its not specifically permitted by this access list it will be dropped by the last rule "deny ip any any".
So for TCP sessions you need to add "permit ip any any established" to your inbound access list (101) which will allow existing connections back into your network.
If you need more than this i.e. UDP then you need to check the link i sent in previos post.
Paddy
paddyxdoyle
Level 6
Level 6
You can add "permit tcp any any established" before your "deny ip any any" rule which will allow established TCP connections back into your internal network. It works by looking for ACK or RST bits in a session, these bits aren't the first bits in a TCP handshake and are therefore part of an established session.
If you need to do similar for UDP traffic then you should look at configuring reflexive access lists.
Please see the following link for details
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca7c3.html
Rgds
Paddy
thanks to all. I will test this out today and post if that worked. I am sure it will
