ACL and OSPF Packets
RMS3
Hi All,
I am currently preparing extended ACLs for my network. I have L3 switches running OSPF and HSRP.
I want to apply an inbound ACL on an interface but I see the OSPF neighbor goes down.
I used Wireshark to go through network traffic and observed that OSPF uses 224.0.0.5 multicast address,I have specifically allowed that as a host in my ACL but OSPF still fails.
Can anyone help me solve this?
10 Replies 10
M02@rt37
Hello @RMS3
Please share here you ACL.
Thanks a lot.
Best regards
balaji.bandi
how is your ACL Look like ?
check this blog what need to allowed :
https://aconaway.com/2008/06/12/acls-and-hsrp-bgp-ospf-vrrp-glbp/
BB
Here is the ACL,please note that I am reconstructing it as I cannot permit "any" as per requirements.
ip access-list extended ALLOW
10 permit ip 10.169.5.0 0.0.0.127 10.169.13.192 0.0.0.31
!HSRP Traffic!
40 permit ip 10.169.5.0 0.0.0.127 host 224.0.0.2
!OSPF Traffic!
50 permit ip 10.169.5.0 0.0.0.127 host 224.0.0.5
60 deny ip any any
exi
Where is this ACL applied, how about other side direction ?
BB
Currently this is the configuration
int vlan 410
ip access-group ALLOW in
exit
The error I get is:
*Nov 30 14:06:22.417 UTC: %OSPF-5-ADJCHG: Process 5, Nbr 10.169.13.227 on Vlan410 from EXSTART to DOWN, Neighbor Down: Too many retransmissions
I looked into the packet using Wireshark,looks like it happens due to LSA Type 4 packet drop
can you post complete bot the side interface config with IP address ?
you mentioned before ACL all works - is this correct ?
BB
How two route have different wildcard'
Try use host in acl if it work then issue with wildcard
I didnt get you,the first rule is to permit 5.0 to reach 13.0.
Friend
Ospf or hsrp is peer to peer connection
And both peet must share same subnet' here is see two different wildcard i.e.it different subnet so I dont think this work.
Can you share config of both peer interfaces that use for ospf and hsrp?
MHM
I have not followed the entire thread, so I am not sure somebody has already mentioned that it might be better to use 'permit ospf' statements:
permit ospf 10.169.5.0 0.0.0.127 10.169.13.192 0.0.0.31
