07-27-2023 01:43 AM
I seem to have gone down a very deep rabbit hole trying to get the IOS on this box upgraded, which has led me here. Luckily this is in a test rig preparing for a live upgrade.
CPLD upgrade seems to go through fine but after the reload the version is the same!
## Basic info:
Cisco IOS XE Software, Version 16.09.08
Router#show platform
Chassis type: ASR1006
Slot Type State Insert time (ago)
0 ASR1000-SIP40 ok 00:03:42
0/0 SPA-8X1FE-TX-V2 ok 00:01:57
R0 ASR1000-RP2 ok, active 00:03:42
F0 ASR1000-ESP100 ok, active 00:03:42
P0 ASR1013/06-PWR-AC ok 00:02:46
Slot CPLD Version Firmware Version
0 00200800 16.3(2r)
R0 13092401 17.3(1r)
F0 12071700 17.3(1r)
Router#show hw-programmable all
Hw-programmable versions
Slot CPLD version FPGA version
R0 13092401 18102401
F0 12071700 N/A
0 00020008 N/A
## Upgrade:
Router#upgrade hw-programmable cpld filename bootflash:asr1000rpx86-hw-programmables.17.02.01.SPA.pkg R0
Start service Upgrade CPLD on Route-Processor 0 from current version 13092401 to 14111801 (Y)es/(N)o/(C)ontinue? [Y] y
Start service This command could take up to 10 minutes, please wait and do not power-cycle the chassis or the card. Otherwise, hardware may be unrecoverable. It is recommended that all cards are running the same version IOS-XE software prior to the upgrade. At the end of upgrade you will be asked to reload the chassis. (Y)es/(N)o/(C)ontinue? [Y] y
Upgrade cpld hw-programmable on Route-Processor 0
The cpld has been successfully upgraded on Route-Processor/0.
PLEASE POWER CYCLE THE CHASSIS NOW.
## After reboot (no change):
F0 12071700 N/A
0 00020008 N/A
07-27-2023 02:12 AM
Hi @Mark07412
I was checking a guide and the command there is "upgrade hw-programmable cpld filename bootflash: <cpld.pkg> RP active"
you are using "upgrade hw-programmable cpld filename bootflash:asr1000rpx86-hw-programmables.17.02.01.SPA.pkg R0"
07-27-2023 02:43 AM
Router#upgrade hw-programmable cpld filename bootflash:asr1000rpx86-hw-programmables.17.02.01.SPA.pkg R0 ?
<cr> <cr>
That's it for this chassis / IOS
07-27-2023 02:26 AM
Not all components can/will support the new ROMMON firmware version.
07-27-2023 02:48 AM
This post is related to CPLD not ROMMON but I did investigate ROMMON and there is a matrix explaining the supported version for each card here
All cards were 16.3(2r) when I started and after upgrades the resulting versions are visible in the outputs above
