ATM troubleshoot.
amagu
Hi all,
I need some help with an ATM issue.
I do not know very well this WAN technologie, and i am facing a big problem.
In fact we have a PVC that is very slow.
I need to check and understand the parameter of our configuration.
Here are the details:
IN THE MOS SIDE :
interface ATM5/0.1 point-to-point
bandwidth 6000
ip address 16.35.42.230 255.255.255.252
ip access-group 108 in
ip access-group 109 out
ip pim sparse-mode
ip ospf cost 2000
pvc mosbbn1 3/150
vbr-nrt 12000 6000 200
oam-pvc manage 60
oam retry 5 10 10
encapsulation aal5snap
IN THE BBN SIDE:
interface ATM4/0/0.2 point-to-point
bandwidth 6000
ip address 16.35.42.229 255.255.255.252
ip accounting access-violations
ip pim sparse-mode
pvc bbnmos 3/150
oam-pvc manage 60
oam retry 5 10 10
Please can you help me to check the parameter with the carrier?
Best Regards,
smif101
Level 4
Level 4
Normally you would put in the distant end IP address under the PVC such as this config
R2(config)#interface atm0.1 point-to-point
R2(config-if)#ip address 12.0.0.1 255.255.255.0
R2(config-if)#pvc 1 300
R2(config-if-vc)#protocol ip 12.0.0.2 broadcast
R2(config-if-vc)#encapsulation aal5snap
R3(config)#interface atm0.1 point-to-point
R3(config-if)#ip address 12.0.0.2 255.255.255.0
R3(config-if)#pvc 1 250
R3(config-if-vc)#protocol ip 12.0.0.1 broadcast
R3(config-if-vc)#encapsulation aal5snap
What does your ping look like end to end. Try it from 32 to 1500 bytes and see if you are dropping packets. I assume you will so from there I would try doing loopbacks to find out where the problem is.
dbellazetin
Level 4
Level 4
Actually you don't need to map the far end ip on point to point interfaces.
Are you seeing CRC's on your ATM interface/s?
Can you post "show int atm x" and "show atm pvc x/x"
Daniel
Hi Daniel,
Here are the results of the command:
mosgw1#sh int atm5/0.1
ATM5/0.1 is up, line protocol is up
Hardware is ENHANCED ATM PA
Internet address is 16.35.42.230/30
MTU 4470 bytes, BW 6000 Kbit, DLY 80 usec,
reliability 255/255, txload 2/255, rxload 6/255
Encapsulation ATM
49974 packets input, 30019875 bytes
43493 packets output, 15356135 bytes
2707 OAM cells input, 2707 OAM cells output
AAL5 CRC errors : 2
AAL5 SAR Timeouts : 0
AAL5 Oversized SDUs : 3
ATM5/0 is up, line protocol is up
MTU 4470 bytes, sub MTU 4470, BW 149760 Kbit, DLY 80 usec,
Encapsulation ATM, loopback not set
Encapsulation(s): AAL5
4095 maximum active VCs, 2 current VCCs
VC idle disconnect time: 300 seconds
0 carrier transitions
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 22:26:54
Input queue: 0/75/4/279 (size/max/drops/flushes); Total output drops: 18
Queueing strategy: Per VC Queueing
1 minute input rate 3886000 bits/sec, 627 packets/sec
1 minute output rate 1296000 bits/sec, 546 packets/sec
22916680 packets input, 3874025835 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 3 giants, 0 throttles
378 input errors, 378 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
21701811 packets output, 3128735920 bytes, 0 underruns
mosgw1#
mosgw1#show atm pvc 3/150
ATM5/0.1: VCD: 1, VPI: 3, VCI: 150, Connection Name: mosbbn1
VBR-NRT, PeakRate: 12000, Average Rate: 6000, Burst Cells: 200
AAL5-LLC/SNAP, etype:0x0, Flags: 0x20, VCmode: 0x0
OAM frequency: 60 second(s), OAM retry frequency: 10 second(s), OAM retry frequency: 10 second(s)
OAM up retry count: 5, OAM down retry count: 10
OAM Loopback status: OAM Received
OAM VC state: Verified
ILMI VC state: Not Managed
VC is managed by OAM.
VC TxRingLimit: 235 particles
VC Rx Limit: 141 particles
InARP frequency: 15 minutes(s)
Transmit priority 4
InPkts: 49985, OutPkts: 43529, InBytes: 30020385, OutBytes: 15358991
InPRoc: 6706, OutPRoc: 12802
InFast: 43279, OutFast: 30727, InAS: 0, OutAS: 0
InPktDrops: 0, OutPktDrops: 0/0/0 (holdq/outputq/total)
CrcErrors: 2, SarTimeOuts: 0, OverSizedSDUs: 3, LengthViolation: 0, CPIErrors: 0
Out CLP=1 Pkts: 0
OAM cells received: 2715
F5 InEndloop: 2715, F5 InSegloop: 0, F5 InAIS: 0, F5 InRDI: 0
F4 InEndloop: 0, F4 InSegloop: 0, F4 InAIS: 0, F4 InRDI: 0
OAM cells sent: 2715
F5 OutEndloop: 2715, F5 OutSegloop: 0, F5 OutRDI: 0
F4 OutEndloop: 0, F4 OutSegloop: 0, F4 OutRDI: 0
OAM cell drops: 0
Status: UP
mosgw1#
You have CRC errors and Input Errors on your ATM 5/0 interface. I would suggest doing "clear counters atm 5/0" and then checking "show int atm 5/0" every few minutes to see if your CRC's and Input Errors are rising quickly. If they are that can be the issue.
A few things that can cause this type of problem.
1) Faulty ATM interface or ATM circuit
2) Traffic shaping is not configured properly (VBR-nrt). You may be transmitting more traffic than you are actually supposed to causing your provider to drop ATM cells. Double check your traffic agreement for your circuit.
3) ATM network is congested and the provider is dropping ATM cells.
I would do the following on both sides of the connection.
clear counters atm x
show int atm x (repeat every few mins. to watch CRCs)
This way you can see if maybe the problem is only in one direction or in both.
Hope this helps.
Daniel
