08-03-2019 12:06 AM
08-06-2019 12:43 AM
Glad it as usefull, if your problem resolved, marks as resolved,
08-03-2019 04:08 AM
yes you can use, the document never mentioned any kind of media for Dual Active Detection. as long as they are reachable should be good and directly connected.
08-03-2019 04:13 PM
HI balaji.bandi,
Thanks reply.
I find some info in "High Availability Configuration Guide"
In the chapter Configuring StackWise Virtual Fast Hello Dual-Active-Detection Link, step3 it says:
Perform one the of the following depending on the switch that you are configuring.
If you are configuring a Cisco Catalyst 9500 Series Switch, use interface { TenGigabitEthernet | FortyGigabitEthernet } <interface>
If you are configuring a Cisco Catalyst 9500 Series High Performance Switch, use interface { HundredGigE | FortyGigabitEthernet | TwentyFiveGigE } <interface>
Example:
Device(config)#interface TenGigabitEthernet1/0/40
So, there is a possible not support GLC-TE ?
08-04-2019 03:25 AM - edited 08-04-2019 03:26 AM
Agreed yor point, But if you have mGIG ports you can use GLC-T for 1 Gig, the port you have mentioned can not go less than 10Gig, (i have not seen eithernet GLC-T for 10G , there may be available in the market, not tested myself)
I will test DAD with 1GIG GLC-T with mGIG port on later week and post the results.
08-04-2019 06:37 PM
Thank you for your support, hopefully get your good news soon!
08-05-2019 10:27 AM
here is test results :
SW1#show interfaces twentyFiveGigE 1/0/2
TwentyFiveGigE1/0/2 is up, line protocol is up (connected)
Hardware is Twenty Five Gigabit Ethernet, address is REMOIVED
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, Auto-speed, link type is auto, media type is 10/100/1000BaseTX SFP
input flow-control is on, output flow-control is off
Last input 00:05:33, output never, output hang never
Last clearing of "show interface" counters 00:33:58
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
19 packets input, 8199 bytes, 0 no buffer
Received 18 broadcasts (18 multicasts)
0 watchdog, 18 multicast, 0 pause input
8 packets output, 4144 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
11 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
SW1#show interfaces twentyFiveGigE 2/0/2
TwentyFiveGigE2/0/2 is up, line protocol is up (connected)
Last input never, output 00:00:51, output hang never
2 packets input, 634 bytes, 0 no buffer
Received 1 broadcasts (1 multicasts)
0 watchdog, 1 multicast, 0 pause input
26 packets output, 10031 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
SW1#show stackwise-virtual dual-active-detection
Dual-Active-Detection Configuration:
Switch Dad port Status
1 TwentyFiveGigE1/0/2 up
2 TwentyFiveGigE2/0/2 up
SW1#show interfaces status | in connected
Twe1/0/2 connected 4094 a-full auto 10/100/1000BaseTX SFP
Twe2/0/2 connected 4094 a-full auto 10/100/1000BaseTX SFP
SW1#show run interface twentyFiveGigE 1/0/2
Building configuration...
Current configuration : 78 bytes
interface TwentyFiveGigE1/0/2
end
08-05-2019 06:58 PM
HI balaji.bandi,
Thank you! Very appreciate your help !
08-06-2019 12:43 AM
